While playing BF3 MP my GPUs are sitting between 50% - 65% usage and im not getting a steady over 144fps. Any ideas?
CPU  i7 6700K @ 4.7GHz | Cooler: Swiftech H220 | RAM: 16GB Corsair Vengeance | GPU: EVGA GTX 1080 SC | Motherboard: Z170X Gaming 7 | PSU: EVGA G2 650W
Storage: 128GB Kingston SSD/1TB WD Black Storage | CASE: NZXT Switch 810 | MONITOR: Acer GN246HL | KEYBOARD: CM Quickfire TK (MX Blue) | MOUSE: Sensei Rival
https://linustechtips.com/topic/101545-660-ti-sli-low-usage-bf3/
It its low usage doesn't it mean its not even trying?
Case: Sentey Eagle Plus Extreme $54 Motherboard: MSI 970A-G46 $78   CPU: AMD FX-6300 $120 Heatsink: cooler master TX3 $30
RAM: G-Skill 8GB DDR3 1866 $77 PSU: COOLER MASTER GX 750w $100 GPU: EVGA GTX 660 Superclock Sig 2 $230  GPU: EVGA GTX 660 Superclock Sig 2 $230
Fans: Cooler Master $12 SLI Bridge: ASUS $8  Hard drive: 2TB western digital $87
https://linustechtips.com/topic/101545-660-ti-sli-low-usage-bf3/#findComment-1357775
Did you always have the SLI 660 Ti's or did you get them recently?  Maybe BF3 just doesn't utilize SLI very well.
recently
https://linustechtips.com/topic/101545-660-ti-sli-low-usage-bf3/#findComment-1357954
Did you set-up a proper sli profile using nvidia inspector?
did you unpark your cpu cores?
sorry for very late reply, ive been busy, but no i didnt set up a sli profile in inspector. I didnt know i had to.
https://linustechtips.com/topic/101545-660-ti-sli-low-usage-bf3/#findComment-1385310
It just means your CPU is hitting it's limit. It's atm just impossible to have 144 fps stable at ultra settings. My 3930K can't push my 780's above 50% in BF3 ->
(watch at 03:50 30%/30% gpu load)
Just raise your clock speed, this game doesn't seem to be taking any advantage of more than 4 cores so I disabled 2 cores & HT, bumped the clock to 4.8GHz and I was getting 50%/50% load at same spot as in my video with 80-90 fps.
https://linustechtips.com/topic/101545-660-ti-sli-low-usage-bf3/#findComment-1386438
That's BF for you. I still love 3 & 4 though.
https://linustechtips.com/topic/101545-660-ti-sli-low-usage-bf3/#findComment-1386469
