Hi
I've discovered that CEX have a strange pricing structure based on the i number of the cpu and storage. Eg a systems with an i5 2400 with 1tb will cost more than one with an i5 4600 with 500gb of storage.
The up shot is there are bargains to be had
The down side is its a pain to search I'm looking for some  recommendations for prebiult systemems that i can add a gt 1050. So manufacture and model number would be good
Max budget £300
https://linustechtips.com/topic/1015297-pre-built-help/
Dell optiplex off ebay and add a 1050
https://linustechtips.com/topic/1015297-pre-built-help/#findComment-12137469
