Wifi/Lan extender without losing the speed?
gta6287
My router/modem is placed 30~ feet away from my room in the living room and I'm planning on connecting my pc with lan cable straight to the router. How can I do that without losing the internet speed? Or should I just use 30+ feet lan cable?
< ̄`ヽ、       /  ̄ >
 ゝ、  \ /⌒ヽ,ノ   /´
   ゝ、 ( ( ͡◉ ͜> ͡◉) /
     >     ,ノ
sorry for my bat englandski
A standard ethernet cable won't impact speed unless it's over 100m in length. A wifi extender will impact speed negatively, usually by a very good bit.
Current Network Layout:
Current Build Log/PC:
Prior Build Log/PC:
so i can the cable without losing the speed? i read it somewhere while ago that i might lose the speed if i use a long ethernet cable
< ̄`ヽ、       /  ̄ >
 ゝ、  \ /⌒ヽ,ノ   /´
   ゝ、 ( ( ͡◉ ͜> ͡◉) /
     >     ,ノ
It will only impact speed if it's longer than 300 feet/100 meters
Prior Build Log/PC:
thanks. i'll get 50m ethernet cable then
< ̄`ヽ、       /  ̄ >
 ゝ、  \ /⌒ヽ,ノ   /´
   ゝ、 ( ( ͡◉ ͜> ͡◉) /
     >     ,ノ
Ummm..
But yeah whoever told you that about 'slowing down' is misinformed, as per Lurick you'll have the same amount of bandwidth up to the 100 meter specification.
PC : 3600 · Crosshair VI WiFi · 2x16GB RGB 3200 · 1080Ti SC2 · 1TB WD SN750 · EVGA 1600G2 · Define C
@beersykins
hah my bad, i got confused between those 2 units. i just bought 30m cat6 ethernet cable which should be arrived in a few days
< ̄`ヽ、       /  ̄ >
 ゝ、  \ /⌒ヽ,ノ   /´
   ゝ、 ( ( ͡◉ ͜> ͡◉) /
     >     ,ノ
