I got the Enthoo Evolv X for Christmas and I've started migrating my system over to it.
In my previous build, which was in the Enthoo Evolv ATX, I used the NZXT Hue+ (1st edition) for RGB. I noticed that the Evolv X use 3-pin headers for the integrated RGB. Is there a way to connect the 3-pin to the Hue+, or do I have to buy the new Hue 2?
My MB is an Asus Maximus Hero VIII, which doesn't have a dedicated RGB header of any sort. (doesn't have a 3.1 header either so the USB C in the front panel is a waste, feelsbadman)
https://linustechtips.com/topic/1014868-rgb-problem/
Not that I can find. I'm in a similar boat, case has 3 pin addressable RGB fans, board has 4 pin analogue RGB header.
From my research the 2 systems are entirely incompatible and one cannot be converted to the other.
Main Rig:-
Server:-
https://linustechtips.com/topic/1014868-rgb-problem/#findComment-12134276
