My CPU is an i3-7100 clocked at 3.9 by while playing just cause 3, the game stutters. At first I thought my CPU was not strong enough but I looked at it in task manager in it is not going past 3.82.
Other specs are -
1050 3Gb
Asus h100m-r?
Seagate baracuda 1tb
Corsair vs350?
What are these for?
https://linustechtips.com/topic/1014790-pc-not-performing-correctly/
Yeah multi core turbo is not 3.9, that's single core. Your the 800MHz difference would not be saving you if the CPU needed more horsepower. I3 turbo is weird though
Primary PC:
PSU tier list
How many watts do I need?
7 minutes ago, epikgamerwmp said:
1050 3Gb
You sure about this?
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
What about the components' temps?
Make sure to tag and/or quote people so they get notified... :P:D
My gear:
                                                         Ryzen 7 2700X / Gigabyte GA-X370M-Gaming 3 / R9 380 Nitro 4GB/ 16GB DDR4 2133 / 225GB OCZ Trion 100 / 3TB of hard drive storage
        AOC C24G1 / BenQ GW2270H(rarely overclocked to 87Hz :P )
        Razer Blackwidow / Redragon Kumara / Logitech G Pro Wiress / Sennheiser HD 559
        Microsoft LifeCam Studio / Tonor BM700 microphone
Panasonic Lumix DC-FZ82 / Canon EOS 80D
#PCMasterrace
Yeah. There is a 3GB version. Which is odd.
Should say 2gb
3 hours ago, Charlie Cherfan said:
Temperatures could be a potential problem. I’d recommend downloading core temp, this will allow you to monitor your temperature to make sure you are not thermal throttling which could be a contributor to the instability issue.
I know that its not thermal throttling.
The 3.9 is the CPU base clock
~60 at full load
What are these for?
2 hours ago, epikgamerwmp said:
~60 at full load
Is every single component running at 60°C under load? ??
My gear:
#PCMasterrace
14 hours ago, epikgamerwmp said:
No, just the cpu
What about the other components then??
My gear:
#PCMasterrace
