I'm going to upgrade my brother's Dell Optiplex 7010, but I'm wondering, is the one looks like 80mm fan in the back of the case enough for the gtx 1050 ti I will be putting in it? I have seen vids of people upgrading Optiplexs and they don't add extra fans so I think its fine but just making sure.
https://linustechtips.com/topic/1014354-will-one-fan-be-enough/
Would it even have place for more fans? I mean, system would benefit from intake fan, but if there isn't slot for it or intake holes, there's no point of having one.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1014354-will-one-fan-be-enough/#findComment-12133219
On 12/29/2018 at 3:44 PM, Owen the Trusty man said:
Is the one looks like 80mm fan in the back of the case enough for the gtx 1050 ti I will be putting in it?
If possible add an intake fan too. Otherwise you might have to run that exhaust at 100% (in order to avoid temps above 70C). I presume you don't want to turn the pc into a hair dryer.
My R2700XT build:  r7 2700 @4.1 Ghz max 65C - Sapphire Pulse rx 5700xt @1625Mhz 955mV 1300rpm fans, max 82C - Asrock B450 gaming k4 - Gskill Ripjaws 2x8GB @3200mhz CL16 - Be Quiet Straight Power E11 650w - Fractal Meshify C - EK-Kit S240 - NB eLoop 120mm PWM - Be Quiet Shadow Wings 140mm 1000rpm - Bitfenix Spectre LED PWM 120mm - Samsung 250GB 860 Evo - Seagate Barracuda 2TB
Peripherals:  Acer XF270HBbmiiprzx 144hz 1080p TN - CM Storm Quickfire TK - Coolermaster MK750 - CM Storm Reaper - Logitech G303 - Logitech G502 - Logitech G603
Audio:  Hyperx Cloud Stinger - Samson SR850 - Trust Screamer - Creative Gigaworks T20 II
https://linustechtips.com/topic/1014354-will-one-fan-be-enough/#findComment-12134212
