Hello,
My brother is getting very poor performance in general, he has been playing The Forest, Fifa 18 and Pubg lately. His specs are as follow:
Athlon X4 860K
EVGA GTX 1050TI SSC
2x8gb DDR3 1600Mhz
EVGA 430W 80+
I've tried just about everthing, from updating drivers, to a clean windows install, still games will stutter and have very poor performance even on low settings. Now I know his cpu may be outdated, but it shouldn't be that much of a bottleneck for a 1050ti and he games at 1440x900, so I don't get why he is getting such performance. His hdd is a very cheap 500gb laptop drive, could that be causing issues? Thanks
AMD Ryzen 7 5700X | MSI B550M Mortar| Corsair H100i | Corsair Vengeance RGB 2x16gb 3000Mhz | PowerColor Reaper 9070 XT | Thermaltake Toughpower GT 850W  | Samnsung 980 Pro 1tb + Crucial MX500 500gb x 2 | NZXT H400
https://linustechtips.com/topic/1014128-poor-performance-help/
Wouldn't happen to be running on an old HDD would you? I've encountered a lot of stuttering once when trying to extend the life on my dying drives, before I realize how bad it can affect my games.
Also those games are quiet CPU intensive, so I would expect a lot of stuttering with this build.
https://linustechtips.com/topic/1014128-poor-performance-help/#findComment-12128572
Well he is using a crappy 500gb laptop drive, it is not that old, but its crappy
https://linustechtips.com/topic/1014128-poor-performance-help/#findComment-12128588
9 minutes ago, PabloSL said:
Hello,
Athlon X4 860K
EVGA GTX 1050TI SSC
2x8gb DDR3 1600Mhz
EVGA 430W 80+
That CPU can barely drive a 760 GTX and you wont get all the frames per second.  So not only you have a CPU bottleneck but seems like with the posts up top that you are committing the cardinal sin here in 2019 and that is to use a hard disk drive :( ..... Get a SSD Get 8GB more ram and overclock that CPU,,, eventually get him a new system, that CPU is a joke for todays demanding needs.  You can hold on to the SSD and RAM when you get new system. Oh shoot it will be DDR3 ,, so ya you gotta replace the mobo the CPU and the RAM.  Your ssd and PSU you can keep.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
https://linustechtips.com/topic/1014128-poor-performance-help/#findComment-12128600
Just now, LukeSavenije said:
have you done any cristaldiskmark or s.m.a.r.t. tests on it? he might have a dying drive
No I haven't, perhaps I should check that, he is currently planning to get a SSD and leave the other drive for storing stuff
https://linustechtips.com/topic/1014128-poor-performance-help/#findComment-12128607
Yes I agree, however I don't think he'll be swapping mobo, cpu and ram right now, hope the SSD helps
https://linustechtips.com/topic/1014128-poor-performance-help/#findComment-12128631
The SSD will change your brothers life man.  Its heavenly.  Youll see when your OS boots in 10 seconds lol and your OS never slows down no matter how many programs you install or how big the registry size it.  Honestly there was a time back in the day when SSD first came out..... it was a better then to upgrade to a SSD then to buy the latest new CPU..... Also 8GB ram is shady,, That can cause hickups and stutters....
https://linustechtips.com/topic/1014128-poor-performance-help/#findComment-12128644
He's got 16 gigs of ram actually, yes I know I use 2 500gb SSDs in my rig, its a night and day difference from a regular hdd
https://linustechtips.com/topic/1014128-poor-performance-help/#findComment-12128659
Oh you do, cool.. Yes ,, I think that's your first thing he needs to upgrade to see instant performance boost.  The 1050Ti is not a bad video card but its still a gamer card where a 1030 sux balls in games but great on the desktop and what not.
https://linustechtips.com/topic/1014128-poor-performance-help/#findComment-12128671
