I need a laptop (running Chrome OS) with Portable Wifi (i think its lte but im not 100% sure)
This laptop will be used for school work and remoting into my VSphere Server
min spec needed
11.6 inch (just nothing like 15 inch so i can it in my bag)
4gb ram+
32gb +
and needs to be from Microcenter or Amazon
Budget 300-500$
Thanks for looking
https://linustechtips.com/topic/1013840-need-help-finding-laptop/
8 minutes ago, wojtepanik said:
have you consider windows machine? x220 will be the same price, but 10x better, pro grade laptop for cheap ass money
Image result for x220
dont get me wrong i love windows but i rather have a chromebook for the android apps and to blend in at school (yes its a good no out of the box reason) and i do have a windows laptop with a i5 and 8gb ram and a ssd
also does the thinkpad have wifi? (portable)
19 minutes ago, Wufflez said:
I heard you could run Linux on a Chromebook in developer mode, but I know very little about this. Just something I know is possible. Thought I would throw the idea out there.
I completely misunderstood the question. You are looking for a Chromebook, sorry.
It's really hard to go wrong with any. Maybe if you gave a budget we'd be better able to narrow down some for you.
lets say a budget of 300-500$ (give me a sec to update it)
Also i have ran Ubuntu on my Chromebook before
