budget Help Finding a New Monitor
I could recommend the monitor I am currently use it, since I love it so much.
https://www.amazon.com/d/Monitors/Viotek-GN24CB-Speakers-Bezel-Less-FreeSync/B078P2XN9M/ref=sr_1_2_sspa?ie=UTF8&qid=1546002637&sr=8-2-spons&keywords=viotek+144hz&psc=1
It's a VA panel which is significantly better than a TN in terms of color accuracy, I have it next to an IPS and they can be hard to tell a picture apart sometimes. You were doing editing so I thought some color accuracy would be important, but I think an IPS would be way out of your price range ($400+). 144hz 4ms response time that can be boosted to 3.1ms. 24". If you're worried about the brand, Viotek is MSI's monitor supplier. MSI has the exact same model, but I decided to go with this brand since they have a "Zero-Tolerance Dead Pixel Policy".
Also, different monitors do not affect your recordings. The only thing that does is resolution.
