[Help]Perfect dual boot guide
Go to solution Solved by MysteriousAeon,
This is a good video and channel for beginners. The info in this video would go for most Linux distros, but in this case, it's for Ubuntu.
On 12/26/2018 at 11:24 AM, jpenguin said:
Separate SSDs is easier
Install  windows first
Windows uses localtime, not UTC/GMT- so tell Linux to use localtime as well
YES that's important and seldom mentioned. The Pane and the Penguin handle the system clock differently, so one or the other needs to be changed to match.  I use Linux almost all of the time, so I decided to change Windows to UTC, but you do you.
