Cable help with g sync
Go to solution Solved by Glenwing,
2 minutes ago, Gibbah said:
I bought a 1440 p Alienware monitor (Idk What monitor exactly) And i use a 2017 razer blade 15 Witch does not have the best i.o... I had many display port cables but could not use them..So i went with HDMI I really wanted to use the g sync and (Special cool stuff lol) So i wanted to use a different cable so i ordered a usb type c to display port cable and i want to know if it is g sync compatible. Thanks Tech people!!
Depends on how the laptop is set up, if the USB-C video is provided from the NVIDIA GPU then yes G-Sync will work, but if it's wired to the Intel integrated graphics (which it is in many laptops) then G-Sync will not work.
https://linustechtips.com/topic/1012758-cable-help-with-g-sync/
https://linustechtips.com/topic/1012758-cable-help-with-g-sync/#findComment-12118449
