I'm looking for the right long term storage solution for me.
It's about photo and video files that need to be stored and saved in the long term. Currently there are about 4tb but it will be more than 10tb on duration
(it should cost as little as possible)
Bluray:
Small steps possible
little space
hdd:
classically
small effort
tape:
high entry price
Cloud:
everything has to be uploaded
running costs
Do i miss any options
what should i use
https://linustechtips.com/topic/1012665-mass-long-term-storage/
If you're doing this to have back ups, it's recommended to follow the 3-2-1 rule:
  • 3 copies of the data
  • 2 copies of the data on different storage devices
  • 1 copy offsite
At the minimum then you should have a local copy on a backup drive (HDD is fine) and a copy somewhere not in your house. The cloud is an option, but so is leaving it with a trusted person or a safety deposit box.
https://linustechtips.com/topic/1012665-mass-long-term-storage/#findComment-12117752
7 minutes ago, Techlas said:
yes i know this rules
but which way is the lowest cost one  and is still safe
I would think HDD.
https://linustechtips.com/topic/1012665-mass-long-term-storage/#findComment-12117804
26 minutes ago, Techlas said:
Bluray:
little space
Bluray is dumb for storing large amounts of data, you're looking at ~80€ or 80$ berfore tax per TB, HDD cost half as much are and faster to read and write to.
PC: Screw day theme users, I guess ¯\_(ツ)_/¯
CPU: R9 3900X @ 4.375GHz All Core MoBo: ASRock X470 Taichi RAM: 2x16GB Mushkin Redline @ 3200MHz 16-18-18-36 GPU: GTX 1080TI FE @ 2088MHz Cooling: Single 60x360mm rad w/ Scythe Kaze Flex, dual 45x540mm external rads passive, Nickel Plexi EKWB blocks, Alphacool VPP755V3 + Watercool Heatkiller Tube 250, Aquacomputer Quadro Case: Inter-Tech 4U 4129-N PSU: Corsair RM1000x Storage: 1TB Samsung 980 M2 SSD, 1TB Seagate Barracuda  Q1 SSD Network: Mellanox ConnectX-3 10G
NAS & Proxmox:
CPU:  Epyc 7302 MoBo: Supermicro H11SSL-i RAM:  8x32GB @ 2666MHz Samsung Registered ECC  Cooling: Enermax Liqtech TR4 II 360 w/ Corsair ML120 Case: InterTech 4F28 PSU: Seasonic Focus PX-650 Storage: 8x6TB HGST + 2x1TB WD Blue SN570 + 2x16GB Intel Optane SSDs Network: Mellanox ConnectX-3 10G
ML-Compute Server:
CPU:  i5 10600K MoBo: MSI MPG Z490 Gaming Plus RAM: 4x8GB HyperX Fury @ 2133MHz8 GPU: Gainward GTX 1080TI Golden Sample Cooling: Single 30 Case: RackMax 2U 8-Bay Storage Case Storage: 512GB Patriot P300 + 4x2TB Seagate Ironwolf NAS Network: Intel Quad 1G
Laptop: Acer Travelmate B117 (absolutely low power, but 12h battery life :D)
Phone: Oneplus Nord
Peripherals:
Monitor: LG 34UC79G + 27GL63T Keyboard: KBDFans 65Rev2 Mouse: Logitech G603 Mousepad: Cheap-ass GMB Mouspad Headphones: AKG K7XX  Other stuff: Novation Launchpad MK2, Aune T1 USB DAC/Amp, Behringer UMC202HD + Audio Technica AT2020 Condenser Mic
Cameras:
DSLR: Canon EOS 600D (Magic Lantern OS) Action Cam: GoPro Hero 3 Silver
Mountainbike:
Frame: Banshee Legend MKIII Fork: Marzocchi 380 C2R2 Titanium Rear shock: Rock Shox Vivid Air/Coil (switched depending on how I feel) Wheels: Spank Spike Race 33 Tires: Maxxis Minion DHR2/DHF Brakes: Magura MT5 Calipers with Shimano XT Levers Deraileur: Shimano Zee, Casette reduced to 6 Speed Crankset: Truvativ Descendant + 38T FSA Chainring Wheight: 16.4kg w/o pedals
https://linustechtips.com/topic/1012665-mass-long-term-storage/#findComment-12117824
At least not in Germany
I come without much searching for a price of 29,99 € for 50 25 gb disks
which equates to a price of 23.99 per tb
https://linustechtips.com/topic/1012665-mass-long-term-storage/#findComment-12117853
I was looking at the 100GB disks, those are around 8€ each. I/O is still pretty slow and to get 10TB in the end, you'd need 400 of the 25GB disks. That's an organization nightmare, two or three HDDs are way easier to deal with and you can get a data recovery service for those. Three 4TB barracudas are propably the best way.
NAS & Proxmox:
ML-Compute Server:
Phone: Oneplus Nord
Peripherals:
Cameras:
Mountainbike:
https://linustechtips.com/topic/1012665-mass-long-term-storage/#findComment-12117910
