I have recently gotten a case that has room for two 120/140mm fans at the front, two 120s at the top, and one 120 at the back. I need to put the radiator at the front because it doesn't fit at the top, It is a 280mm radiator. I have six fans total (two for my radiator) and the rest of the fans are 120mm. I can occupy all places to put the fans in, but which way should the fans be blowing? Thanks in advance!
https://linustechtips.com/topic/1012447-case-fan-direction/
Idealy, you want to exhaust hot air.
Idealy u want to intake filtered air.
So..
If your top fan positions have a filter use them as intake,
use the rear as exhaust as they pritty much never have a filter. (though maybe have it runing at low rpm)
And have the front fans as exhaust.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
https://linustechtips.com/topic/1012447-case-fan-direction/#findComment-12116284
So..
That is what I am going to do, I am going to exchange 2 120mm fans for 140mm ($3 extra) and then put those two at the top, have a 120 for exhaust at the back side, and the radiator as exhaust.
https://linustechtips.com/topic/1012447-case-fan-direction/#findComment-12116328
