I am currently running an Asus ROG GL553VD with 1050 and looking to upgrade to a full PC. I have my gaming keyboard, mouse, and headphone. I would like recommendations for a build that is a significant upgrade to what I currently have. I aim to game at ultra 1080p or 1440p, 60+ FPS is fine as I don't do much competitive FPS.
https://linustechtips.com/topic/1012111-need-help-for-first-pc-build/
Primary PC:
PSU tier list
How many watts do I need?
What's your budget and location?
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
22 minutes ago, fasauceome said:
He can build a 9600k for cheaper. Also can find a z390 board for cheaper as well. He can also find a 1070 for cheaper as well.
The above build is a bad example, at that total price might as well go with the 8700k
The 9600k is listed for 10 cents more, and it's basically the same product so yeah of course it's the same price. I definitely don't see how a 9600k would be cheaper than an 8600k
Primary PC:
PSU tier list
Lol so you are saying he shouldn't spend the extra ten cents for something newer......LMAO! What i meant was it is cheaper in the long run he wont have to upgrade as quick. You have him going with an almost not supported chipset as well.
Anyways,
here is a edit of r2724's build
PCPartPicker part list: https://pcpartpicker.com/list/fLxDNQ
Price breakdown by merchant: https://pcpartpicker.com/list/fLxDNQ/by_merchant/
CPU: Intel - Core i5-9600K 3.7 GHz 6-Core Processor  ($259.99 @ Amazon)
CPU Cooler: CRYORIG - C7 40.5 CFM CPU Cooler  ($32.99 @ Amazon)
Motherboard: MSI - MAG Z390 TOMAHAWK ATX LGA1151 Motherboard  ($152.82 @ B&H)
Memory: Corsair - Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 Memory  ($119.99 @ Amazon)
Storage: Samsung - 860 Evo 500 GB 2.5" Solid State Drive  ($71.00 @ Newegg)
Storage: Western Digital - Caviar Blue 1 TB 3.5" 7200RPM Internal Hard Drive  ($44.89 @ OutletPC)
Video Card: Gigabyte - GeForce GTX 1070 8 GB Windforce OC Video Card  ($314.89 @ OutletPC)
Case: Fractal Design - Meshify C TG ATX Mid Tower Case  ($91.99 @ Amazon)
Power Supply: Corsair - RMx (2018) 650 W 80+ Gold Certified Fully-Modular ATX Power Supply  ($73.98 @ Newegg)
Total: $1162.54
Generated by PCPartPicker 2018-12-24 13:38 EST-0500
Saved you money in the long run and got you a z390 board for future proofing yourself a bit.
You added a terrible CPU cooler (for the 9600K), a crappy motherboard, and a graphics card weaker than the RTX 1070. No shit you'll save money.
And Intel is not releasing any more CPUs for the Z390 chipset (at least ones that the OP might want to upgrade to).
And what exactly is "future proofing" in your words?
By future proofing i was referring to the other posters z370 chip set board. which is almost the same price as your z390 you posted earlier. We both saved him money in the long run either way. So no need to throw insults. I was disagreeing with dasauce's build because it is a little much, especially for the z370 chipset. You especially saved him money by going the z390. Yes your mobo is better. I was just trying to save him a touch more money. I mean really why would we make the original poster pay $20 more for an older chip set...i mean common. The motherboard you posted r272 will be better.
Anyways,
He wont need an RTX. From my readings the current RTX's out now don't have that much more performance depending on the game. What I am saying is wait for some better GPU's to come out that will be worth his while. Personally id go with a 1070 and save that extra $120 or so and put it toward a new monitor or whatever. In fact, only a handful of games only announced they will be supporting ray tracing of the rtx 2000. Will it be the next big thing? sure! Right now the 1070 is doing an excellent job of holding out for now. Right now the 2000 series are not must have upgrades or builds right now. Last time around, buying a GTX 980, which was about the same price as the GTX 1070, was a sucker move. But this year, buying a GTX 1080 or 1070 for less than a RTX 2070 might be a smart move if you’re not interested in ray-tracing. If you’re on the lookout for a card that can play any of today’s top games in 4K at high, though, the answer is clear: wait two months, and buy a GTX 1070 for likely  even less than it costs today. If you’re willing to go second-hand, you could get a real steal from someone on the second-hand market.
Boggling my mind here man. They are the same age, they are nearly the same product. One has solder in it.
None of this makes any sense. Getting an 8600k or a 9600k will put OP on the exact same time to the next upgrade. And how on Earth is the Z370 chipset supported? The Z87 chipset for 4th gen gets BIOS and updates.
future proofing
This is the Crux of your misunderstanding. There's no such thing as future proof, as nobody can see the future. The 8600k and the 9600k are equally well equipped going forward, as they have the same core count and same microarchitectures
Primary PC:
PSU tier list
Heres the thing why make the OG poster pay $20 more for a older chip set when r272 found a newer chip set motherboard for cheaper. You are right, based on user benchmarks there is not a lot of difference regarding the 8600k vs 9600k. Still for almost the identical same price why not just have him buy the newer one? Performance wise yes nearly the same. However until the 8600k goes down in price. The OG poster is better off getting something newer.
https://cpu.userbenchmark.com/Compare/Intel-Core-i5-9600K-vs-Intel-Core-i5-8600K/4031vs3941
You are right, i used the wrong terminology here regarding future proofing. I am trying to make his PC last longer while also trying to save him money. However, I still think r272's build motherboard wise is better and i am not refering to performance wise. r272 saved him about $400.
I still think r272's build motherboard wise is better not performance wise of course
The ASRock board probably has similar power delivery to the board I linked, but the EVGA board has more features. They can both be upgraded the same amount, so if OP wants to have more I/O options and what not, it's a good $10 to invest. Otherwise, the 390 board would be an easy way to save.
Primary PC:
PSU tier list
