Motherboard or CPU dead?
Go to solution Solved by z3r0r0,
Hello guys.
The issue was resolved by replacing the CPU. Maybe my overclock settings were not correct due to the limited VRM options for the motherboard I have...  Might as well limit my OC settings or not OC at all and read more about overclocking my board. Thanks for the help guys.
Specs:
CPU: Ryzen 5 2600X
Mobo: X470 AORUS GAMING 5 WIFI
RAM: Trident Z RGB GTZR 3200Mhz - 8GBx2
CPU Cooler: Auraflow 120
PSU: Seasonic focus+ gold 650fx
GPU: ROG STRIX-GTX1060-O6G-GAMING
Hello, I'm new in the forums.
I'm seeking advice whether if the Mobo or CPU is dead?
The problem is whenever I boot up the desktop, It will boot up and the screen remains black(NO POST). I tried all the solutions and my Mobo has an indicator on the lower right where the CPU led is Red meaning CPU failed or not detected. The only thing that I didn't tried is having extra parts to isolate the problem.
Before the problem happened, I updated my Bios to its latest firmware. After a while, it is still running perfectly with no errors. Then sometime later, my problem arrived.
Yes I OC my CPU via Ryzen Master but I'm not using the machine under heavy load and I only use it during the weekends. I just stress test it like 4-5 times since I built it and it was running fine with no errors.
Thanks in advance for the answers.
https://linustechtips.com/topic/1012015-motherboard-or-cpu-dead/
Just now, SidM said:
How about taking out the cpu and checking for bent pins on the mobo? I know I may sound a little stupid as you didn't mess with the CPU in any way but whats the harm in checking
I forgot to tell that I also reseated the CPU and I spent 30 mins on checking every row/column to see if there were bent pins. I also tried using a credit card to see if there were any bent pins but no bent pins... I also properly ground myself.
ok, i was gonna say that something might have shorted out, but then you were grounded.....
is there any hardware store near you? or some friend who also has a ryzen build? I would recommend putting the CPU in another mobo and then trying for a post on that system. You could also insert some other CPU into your current mobo and try for a post. This will most likely isolate the error and will let you know what is fault-the CPU or mobo.
1 minute ago, SidM said:
before that try clearing the cmos and flasing the latest bios from the manufacturers website again.
Cannot reflash the bios on my current situation but will take note of that. I will try borrowing from a friend and will post the results here. thanks for the help.
Have you cleared the cmos
Optical Drive Poll: https://linustechtips.com/main/topic/1006309-optical-drive-survey/
Main Rig (Redshift)
CPU: Ryzen 7 9800X3DX MOBO: MSI MAG X870E Tomahawk WIFI RAM: G.Skill Flare X5 (2x16gb) 6000MT/s 28-36-36-96 GPU: Sapphire NITRO+ 9070XT, Cooler: Noctua NH-D15 Chromax Storage:  Intel S3520 150gb x4 RAID0 for boot, Crucial P310 4tb x2 RAID0, MSI Spatium M470 1tb, SK Hynix Platinum P41 2tb,  Case: Phanteks Evolv X2 PSU: Seasonic Foucs GX 850W OS: Windows 11 Pro 64 bit
HexOS Server (Vault)
CPU: Xeon E5-2603v3 MOBO: MSI X99 Tomahawk RAM: G.Skill Aegis (4x8gb) 3000MT/s 16-18-18-38 GPU: Headless Cooler: Cooler Master Hyper 212 LED Storage: Intel S3520 150gb x2 for boot RAID1, x16 in RAIDZ1 for storage, LSI 9305-16i HBA,  Case: Phanteks Enthoo Pro Tempered Glass PSU: EVGA SupeNOVA G1+ 750W
15 hours ago, SidM said:
k best of luck. Just as a side note, im pretty sure ryzen mobos can flash without cpu or ram.
They can't that's why you need a first gen chip to get a 300 series board a bios that will work with 2nd gen
Main Rig (Redshift)
  • 3 weeks later...
Hello guys.
