https://linustechtips.com/topic/1011847-updated-build/
1 minute ago, Orbity said:
I want to but I cant
how come you can't? Is there a reason you need a pc immediately?
8086k
aorus pro z390
noctua nh-d15s chromax w black cover
evga 3070 ultra
samsung 128gb, adata swordfish 1tb, wd blue 1tb
seasonic 620w dogballs psu
https://linustechtips.com/topic/1011847-updated-build/#findComment-12111530
good point but I just been stuck with this laptop that cant run anything and I really want to upgrade. Is the better mobo necessary? Will it effect the life of the build? What makes it better? Will it cause any problems (as it is now)?
https://linustechtips.com/topic/1011847-updated-build/#findComment-12111537
a better motherboard would have more features and better overclocking
8086k
aorus pro z390
evga 3070 ultra
https://linustechtips.com/topic/1011847-updated-build/#findComment-12111540
So a more expensive motherboard is better for OC and has a few more features like? Will the cheaper motherboard work fine just I need to be a little cautious about oc?
https://linustechtips.com/topic/1011847-updated-build/#findComment-12111548
yeah, but I think there might be better motherboards in the price range you're in
8086k
aorus pro z390
evga 3070 ultra
https://linustechtips.com/topic/1011847-updated-build/#findComment-12111552
A B450M Pro4 is 79.99$ at Microcenter, so get that. It should be fine for OC (although you will not be able to push it extremely far)
Ryzen 7 3700X / 16GB RAM / Optane SSD / GTX 1650 / Solus Linux
https://linustechtips.com/topic/1011847-updated-build/#findComment-12111553
I asked some one if the B450M Pro4 or the Asus PRIME B450M was better and people said the Asus was better, do you think the pro4 is better? thanks
https://linustechtips.com/topic/1011847-updated-build/#findComment-12111558
not the entire USA has microcenters, I don't have any here in oregon... Hopefully the OP has one.
8086k
aorus pro z390
evga 3070 ultra
https://linustechtips.com/topic/1011847-updated-build/#findComment-12111562
I know, it's just that if he does have one then he's good.
It's also 79.99$ at Amazon, but it's Prime-only.
https://linustechtips.com/topic/1011847-updated-build/#findComment-12111566
8086k
aorus pro z390
evga 3070 ultra
https://linustechtips.com/topic/1011847-updated-build/#findComment-12111571
We have frys electronics in Oregon
 fellow Oregonian? Fry's kinda sucks tbh, online is your best bet without microcenter
8086k
aorus pro z390
evga 3070 ultra
https://linustechtips.com/topic/1011847-updated-build/#findComment-12111573
you like the pro4 better?
Asus is known to overprice their products because they're Asus, so I have a gut feeling that you don't get much for what you pay compared to ASRock
8086k
aorus pro z390
evga 3070 ultra
https://linustechtips.com/topic/1011847-updated-build/#findComment-12111577
you know asrock was asus untill 2006, right? kinda agree tho. maybe the atx? a while back, i saw it on sale for 60 bucks, so if you can wait a while...
https://linustechtips.com/topic/1011847-updated-build/#findComment-12111598
I was 3 years old in 2006 so I probably didn't catch that. I feel like ASRock has a little bit better pricing than asus though.
8086k
aorus pro z390
evga 3070 ultra
https://linustechtips.com/topic/1011847-updated-build/#findComment-12111604
wow, same. It looks like ASRock has better price to performance but Asus might have better "quality"
https://linustechtips.com/topic/1011847-updated-build/#findComment-12111614
quality is relative. Oh well, I still recommend the pro4 b450, for what you're doing. I ended up getting the gigabyte z390 aorus pro
8086k
aorus pro z390
evga 3070 ultra
https://linustechtips.com/topic/1011847-updated-build/#findComment-12111616
