4 minutes ago, aman12 said:
Any one reply good gaming and streaming pc under 500 usd
unless your streaming minecraft on the lowest setting possible streaming it on the same PC will be like walking through a sand storm with legos dumped on the desert floor GG's mate
https://linustechtips.com/topic/1011152-help-regarding-new-pc/#findComment-12106245
you aint streaming and playing fortnite at 60fps for 500 dollarie doos
CPU: i7 4790k
GPU: Gigabyte Windforce3 GTX 1080
RAM: 8GB Corsair Vengance 1600MHz (@1333Mhz) + 8GB Balisticx Sport or something 1333MHz
MOBO: MSI Z97 Gaming 5
PSU: 1000W EVGA 1000G 80+ GOLD
Case: Dark Base 700
Cooling: Dark Rock Pro 3 CPU Cooler + Standard Case Fans
Drives: Intel SSD5 180GB (Boot Drive) + Seagate Baracuda 1TB HDD + Seagate Baracuda 4TB HDD
Keyboard: Razer Blackwidow RGB 2013
Mouse: Corsair Harpoon RGB
Speakers: Creative T15 Bluetooth Speakers
Microphone: Samson Meteor Mic
Monitor: AOC G2590VXQ 75Hz + ASUS VS247 + Shitty Generic 1080p 60Hz TV
LED Controller: NZXT HUE+
https://linustechtips.com/topic/1011152-help-regarding-new-pc/#findComment-12106252
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor  ($164.99 @ Amazon)
Motherboard: Gigabyte - B450M DS3H Micro ATX AM4 Motherboard  ($73.98 @ Newegg)
Memory: Team - Vulcan 8 GB (2 x 4 GB) DDR4-3000 Memory  ($61.98 @ Newegg)
Storage: Kingston - A400 240 GB 2.5" Solid State Drive  ($36.99 @ Amazon)
Case: Cougar - MX330 ATX Mid Tower Case  ($39.99 @ Newegg)
Power Supply: Corsair - CXM 550 W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($49.99 @ Amazon)
Other: Used graphics card (580?) ($120.00)
Other: greymarket OS ($15.00)
Total: $562.92
Generated by PCPartPicker 2018-12-21 18:42 EST-0500
This is like bare minimum I would go if I wanted to stream.
Current Desktop Build | 2200G | RX 580 4GB | 8GB RAM | CTRL | Logitech G Pro Wireless
Laptop | 2018 MBA 256/16GB | MX Master
https://linustechtips.com/topic/1011152-help-regarding-new-pc/#findComment-12106291
CPU: AMD - Ryzen 3 2200G 3.5 GHz Quad-Core Processor  ($93.99 @ Amazon)
Motherboard: ASRock - AB350 Pro4 ATX AM4 Motherboard  ($65.02 @ OutletPC)
Memory: G.Skill - Aegis 8 GB (1 x 8 GB) DDR4-3000 Memory  ($53.99 @ Newegg)
Storage: Team - L5 LITE 240 GB 2.5" Solid State Drive  ($29.99 @ Newegg)
Storage: Toshiba - P300 1 TB 3.5" 7200RPM Internal Hard Drive  ($39.99 @ Walmart)
Video Card: PowerColor - Radeon RX 570 4 GB RED DRAGON Video Card  ($139.99 @ Newegg)
Case: RAIJINTEK - ARCADIA WHITE ATX Mid Tower Case  ($32.49 @ Amazon) ignore the warnings related to this case, it's just PCPP's screwup.
Power Supply: Corsair - CX (2017) 450 W 80+ Bronze Certified ATX Power Supply  ($43.89 @ OutletPC)
Total: $499.35
Generated by PCPartPicker 2018-12-21 22:01 EST-0500
https://linustechtips.com/topic/1011152-help-regarding-new-pc/#findComment-12106698
