Hi guys, please recommend me a laptop for work.
I need to replace my desktop pc with a laptop. Pc i have now ( i5-3470, HyperX HX316C10F/4  4gbx4, gtx970 4gb)
I need to find something with better performance
I use 2d,3d graphic software, handling big size files, rendering and stuff
Need great quality display, 15'' at least, ssd at least 512 gb +ssd\hdd, graphic card 4-6 gb, ram 16-32 gb
budget  <2500$
I want to buy a laptop that does not need to be changed in 2-3 years
Thank you!
https://linustechtips.com/topic/1011036-recommend-laptop-for-work/
budget  <2500$
Thank you!
For work, I would recommend best Thinkpad you can fit in your budget.
CPU i7 8700k MB  Asrock Z370 Killer SLI/ac GPU EVGA GTX1060 6 GB RAM 16GB DDR4 Gskill Ripjaw 3200 Mhz PSU EVGA SuperNova 750 G1+Storage 1x1TB WD Blue + 250GB WD Blue M.2 CASE Fractal design define C
42 minutes ago, Nikolai_t said:
budget  <2500$
Locaton? Preferred max weight in kg/lbs and min battery life in hours? Need Quadro GPU?
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
