I started a build in 2016, an currently using a Gigabyte AMD FM2+ A68H SATA 6Gb/s USB 3.0 mATX ATX DDR3 2133 NA Motherboards GA-F2A68HM-H with a AMD AMD A6-7400K Dual-Core 3.5 GHz Socket FM2+ Desktop Processor Radeon R5 Series, I need to upgrade my proccesor for my gaming any idea on what cpu i could get that would fit this motherboard an run better than what i have???
https://linustechtips.com/topic/1010610-cpu-help/
Here is the supported CPU's for your motherboard you can take a look and see what ones fit your budget. https://www.gigabyte.com/Motherboard/GA-F2A68HM-H-rev-10#support-cpu
https://linustechtips.com/topic/1010610-cpu-help/#findComment-12101271
why would he ever spend money on FM2+ in 2018?
like if he is on a super budet, shure, but it is hard to justify.
https://linustechtips.com/topic/1010610-cpu-help/#findComment-12101278
Yea, Would be best to upgrade mobo ect, but in his question he was asking for CPU's that will fit his current motherboard.
https://linustechtips.com/topic/1010610-cpu-help/#findComment-12101282
Why even bother, just get rid of the entire platform. Even Sandy Bridge 2500k is a big improvement, and that's fast enough to be a decent mid range CPU for games when overclocked.
Desktop benching:
https://linustechtips.com/topic/1010610-cpu-help/#findComment-12101340
I highly recommend you change to a newer platform. Even going with AM4 and the cheapest Ryzen 3 would be a huge upgrade for you and you'd see an incredible performance difference.
Intel Core i7 9700F / Cooler Master 212 Evo / GeForce GTX 1660 SUPER / 16 GB G.SKILL RAM @ 2666MHz / GA-B365M-DS3H / EVGA 500w PSU
HP Pavilion Gaming 15 / Ryzen 5 4600H / GeForce GTX 1050 / 8 GB @ 3200MHz
https://linustechtips.com/topic/1010610-cpu-help/#findComment-12101345
