So, I use my PC mainly for Streaming and Gaming, I recently updated to Ryzen,
ASUS CROSSHAIR VII HERO X470
CPU RYZEN 2700X
16GB DDR4 @ 3000HZ
Since I updated my system, I've been able to stream games like Fortnite, at 1080p 60Fps on the Medium Preset.
As of Last week I've been unable to do so, I am not sure what is causing the problem, task manager shows CPU usage near 100% when streaming, when previously it wouldn't go past 60%.
I am currently at a loss and actively seeking for help.
https://linustechtips.com/topic/1010494-cpu-usage-help/
Shows obs jumping between 30 to 70% usage depending ont he movement on my game, the thing is that I've used these presets before, and I never had a problem until just recently, I already did a fresh install of all my drivers and windows and the problem continues, CPU temps are also normal, between 46 and 50 degrees while both gaming and streaming
https://linustechtips.com/topic/1010494-cpu-usage-help/#findComment-12100308
