PC randomly crashes using certain applications
Recently, I've been having an issue where my computer will randomly crash. The three applications I've noticed this in are Block Ops 4, Epic Battle Fantasy 5, and A Hat in Time. When this crash occurs, both monitors freeze, sound stops, and the RGB on my keyboard and mouse stop moving. The only "solution" I've found to fix this is to hard reset the computer with the power button. This problem first arose during a NVIDIA driver update to version 417.01 where my monitor screens turned black during installation and remained that way until a hard reboot. Turning on the computer again showed that the drivers were installed successfully strangely enough. I've since updated my drivers and used a DDU.
Some things I've noted and tried:
  • Updating to the latest graphics drivers
  • Using a display driver uninstaller (DDU)
  • Updating Windows
I have MSI Afterburner on, however nothing is overclocked at default settings.
I've caught my computer crashing with Afterburner's statistics open. Nothing seemed out of the ordinary.
My computer has been running at a stale CPU clock of 3.675 GHz before this problem occurred.
My entire list of specs:
  • 16 GB RAM (2x8GB DDR4-3200)
  • AMD Ryzen 7 1700 @ 3.675 GHz
  • GIGABYTE GeForce GTX 1080 Ti OC 11GB
  • EVGA SuperNOVA 650 G3, 80 Plus Gold 650W, Fully Modular
Windows 10 Home 64-bit - Version 10.0.17763 Build 17763
Latest BIOS version of: American Megatrends Inc. P5.10, 10/16/2018
Notable apps running at time of crash:
  • Wallpaper Engine
  • Discord
  • Steam
  • Rainmeter
  • MSI Afterburner
  • Lightshot
  • VIVEPORT
  • Corsair Utility Engine
  • Epic Games Launcher
Try not using Wallpaper Engine, it used to make my desktop crash as its unstable.
MSI MAG X670E TOMAHAWK WIFI Motherboard, AMD Ryzen 9 7900X3D Desk-top Processor (12-core/24-thread, 140MB cache, up to 5.6 GHz max boost), CORSAIR VENGEANCE DDR5 RAM 32GB (2x16GB) 6000MHz CL30 AMD EXPO iCUE Compatible Computer Memory, Samsung 990 PRO NVMe M.2 SSD, 2 TB, PCIe 4.0, 7,450 MB/s read, 6,900 MB/s write, Internal SSD, 2 x Seagate BarraCuda 4 TB Internal Hard Drive HDD – 3.5 Inch SATA 6 Gb/s 5400 RPM 256 MB Cache for Computer Desktop PC Laptop (ST4000DM004), MSI MPG A1000G PCIE5 Power Supply Unit, UK Plug - 1000W, 80 Plus Gold Certified, Fully Modular ATX 3.0, PCIe 5.0 GPU, XILENCE XC982 LQ240PRO AIO COOLER, XFX Speedster MERC 310 AMD Radeon RX 7900 XT 20GB 1 x AOC CU34G2XE & 1 x Samsung U32J59XUQ 3840 x 2160 4K, 1 x Samsung Evo 970 Evo Plus NVME PCI-E 1TB, 1 x Samsung Evo 850 250GB, 1 X Sandisk Ultra II SSD 240GB + 2 X 4TB Seagate Barracuda SATA III,  MZHOU 7 Ports PCIe USB 3.0 Card,  2 x UGREEN Hard Drive Enclosure 3.5 inch External SATA Disk Caddy Reader USB 3.0 2.5 3.5 HDD SSD 16TB UASP Case Dock Station With 12V 2A Power Adapter For Windows with 6TB Seagate Barracuda SATA III, Fractal Design Pop XL Case + 4 Fractal Design 140mm Case Fans, Logitech MX Vertical & MX Ergo Trackball Mouse using same USB unifying device, Microsoft Ergonomic Keyboard, Windows 11 Pro x64 Retail, 6TB Seagate USB 3.0 Backup Plus Hub, Blue Yeti Microphone, Logitech C922 Pro HD,  Logitech C920 Pro HD, Bit Defender Total Security 2021.
Second PC (Cyclops) - MSI 990FXA Gaming, AMD FX 8370 4Ghz, Corsair 16GB Vengeance Red 9-9-9-24 1600Mhz, Arctic Cooling Freezer 13, Asus Strix 1050TI 4GB, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 1 x Samsung Evo 850 250GB, 2 X Seagate Barracuda 2TB, 1 X WD Black 2TB, 1 x ASUS 16x DVDRW, X-Case Eagle III Case, 3 X Corsair AF 120 Case Fans, EVGA 850 G2 80+ Gold + PSU, Logitech MX Master Mouse, Corsair K30 Keyboard, Logitech C920 Webcam, R0DE NT1-A Microphone, Scarlet 212 Audio Interface (Revision 2), Windows 10 Pro X64 Retail, Bit Defender Total Security 2021, 2TB Seagate Expansion USB Hard Drive.
Third PC (Old Trustie) - Acer Aspire M3400, OEM Mainboard, AMD FX Athlon II X3 425 2.7Ghz, 16GB Corsair Value 1600Mhz Ram, OEM CPU Cooler, AMD R7 260 2GB GPU, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 2TB Samsung SATA III, 1 X OEM 16X DVDRW, 1 X Acer OEM Case, 1 X Corsair AF120 Case Can, Corsair CX500 Bronze+ CPU, Logitech MX Master Mouse, Corsair K30 Keyboard, Windows 10 Home X64 OEM, Logitech C920 Webcam, Bit Defender Total Security 2021.
Printers Include - Canon MG5750, Canon, IP8750,  Canon Pixma Mega tank G5050 & 2 X Samsung Xpress C410W.
1 X Zexrow Xbox360 Wired Game Controller.
TP Link Archer AX6000 Cable Router Wifi6 with a Virgin Media Hub 4.0 in Modem only mode running 1GB Fibre internet.
Samsung Galaxy S21+ 256GB Mobile Phone.
Internet Speed.....
https://www.speedtest.net/result/9935039193
2 minutes ago, facefaceface said:
Hi, I have a similar issue, But now that I come to think of it it used to stop crashing when I had closed Discord, Probably not the issue though.
Also have you pirated ur windows? from KMSpico possibly?
I am using genuine Windows 10 Home x64
