Possible GPU Problem?
Go to solution Solved by Waqas409,
14 minutes ago, Maxisthemoose said:
So sometimes when I am on my computer, my monitor screen will randomly show no signal and all audio stops. Sometimes it is under load and sometimes it isn't. It was happening when my GPU was a 1060 6gb, now it is a 1070 ti (Still happening). I replaced my PSU, 500W EVGA 80+ Bronze to a 650W EVGA 80+ Gold.  I have all of my Drivers updated and I have tried DDU. No luck so far. When the screen shows no signal, the PC itself continues running but all audio turns of and the lights on only my mouse go out.
All my power cables are fully plugged in and I have tried so many things. Thank you in advance.
(I have set all overclocks to default factory settings and it still happens)
OMG you also have this issue?
I thought there was something bad happening with my System.
Here is the quick fix.
This issue is caused by the 4xx drivers ( confirmed ).
I switched back to 388.xx driver version now everything is working fine for me.
PS: i also have GTX 1070Ti.
Main And Only Build : CPU : Ryzen 5 1600x (OC to 4.2GHz), Cooler : Thermaltake Floe Riing RGB 240 TT Premium Edition, Motherboard : Asus ROG Strix B450-F Gaming, RAM : Trident Z RGB 16GB (2*8) 3000Mhz DDR4, GPU : Gigabyte Gaming GTX 1070 TI, PSU : EVGA G3 650W 80+ Gold Certified, Storage : 250GB Samsung 860 Evo + 256GB SU800 + 2TB Seagate HDD.
https://linustechtips.com/topic/1010131-possible-gpu-problem/
Just now, Happycowdance said:
could be an issue with your mobo
I really hope not because then I'm going to have a pain getting Windows reactivated... could be though
https://linustechtips.com/topic/1010131-possible-gpu-problem/#findComment-12097223
Have you tried a different monitor or different display input port on your current monitor? It could be a capacitor issue with your monitor itself causing to get disconnected momentarily. I have this issue with an old Dell monitor on one of my rigs. Only does it with DVI, not VGA.
QUOTE ME IF YOU WANT A REPLY!
PC #1
Ryzen 7 3700x@4.4ghz (All core) | MSI X470 Gaming Pro Carbon | Crucial Ballistix 2x16gb (OC 3600mhz)
MSI GTX 1080 8gb | SoundBlaster ZXR | Corsair HX850
Samsung 960 256gb | Samsung 860 1gb | Samsung 850 500gb
HGST 4tb, HGST 2tb | Seagate 2tb | Seagate 2tb
Custom CPU/GPU water loop
PC #2
Ryzen 7 1700@3.8ghz (All core) | Aorus AX370 Gaming K5 | Vengeance LED 3200mhz 2x8gb
Sapphire R9 290x 4gb | Asus Xonar DS | Corsair RM650
Samsung 850 128gb | Intel 240gb | Seagate 2tb
Corsair H80iGT AIO
Laptop
Core i7 6700HQ | Samsung 2400mhz 2x8gb DDR4
GTX 1060M 3gb | FiiO E10k DAC
Samsung 950 256gb | Sandisk Ultra 2tb SSD
https://linustechtips.com/topic/1010131-possible-gpu-problem/#findComment-12097235
No I have not, but I also switched from 1080p to 1440p, so I'm not sure. I'll try that.
Also, some pictures, doubt it will help but here.444536600_20181218_2136411.thumb.jpg.669f4008eab7abfabb462b496e5793fb.jpg
Pixio PX276
Edited by Maxisthemoose
Monitor Type
https://linustechtips.com/topic/1010131-possible-gpu-problem/#findComment-12097239
Ryzen 5 3600 | MSI B450 Tomahawk Max | Corsair Vengeance lpx 32gb 3600mhz | EVGA GeForce RTX 3080 FTW3 ULTRA GAMING | XPG Core Reactor 850w
https://linustechtips.com/topic/1010131-possible-gpu-problem/#findComment-12097265
4 minutes ago, Waqas409 said:
388.xx
The oldest driver on their website is 399.24... at least that I can find, if you have a link to the driver you are using can you please share that? Thanks for the advice!
https://linustechtips.com/topic/1010131-possible-gpu-problem/#findComment-12097273
you can always go on guru3d and download old drivers from there if you want.
Here is the link.
https://www.guru3d.com/files-details/geforce-388-71-whql-driver-download.html
https://linustechtips.com/topic/1010131-possible-gpu-problem/#findComment-12097274
Ok thank you, I wasn't sure if that was safe, thanks!
https://linustechtips.com/topic/1010131-possible-gpu-problem/#findComment-12097276
Ahh interesting, that problem mentioned by OP happened to me too a week ago :o
Do you have the source that confirms the 4xx driver issue?
https://linustechtips.com/topic/1010131-possible-gpu-problem/#findComment-12098906
i had the issue with 4xx, so consider me the source, also if you having same issue try the 3xx drivers, you will become the source too.
https://linustechtips.com/topic/1010131-possible-gpu-problem/#findComment-12100684
Thank you so much honestly. This has completely stopped the problem and now my GPU temps are also cooler. It was running at 38ishC with 4xx Drivers installed and now with the 388.71 Drivers its temps have gone down to 30ishC idle. Also under load the temps went down and my FPS went up! Was running 80C under 100% load with around 50-60 FPS Max settings 1440p on The Witcher 3 and now running at 60-70C with 70-80 FPS same settings.
Thank you so much!!!!
30C not 32C Idle
https://linustechtips.com/topic/1010131-possible-gpu-problem/#findComment-12108205
