2 minutes ago, Airpewdiepie said:
 Should i replace battery?
Yep. If its a charging issue its most likely an issue with the battery not anything else.
Maybe try a different cable and make sure its not running while you are charging it
https://linustechtips.com/topic/1010130-serious-battery-issues/#findComment-12097218
Thx, it charges for 10 hours as i said, i will try a different cable, and even a "power brick" before changing battery
https://linustechtips.com/topic/1010130-serious-battery-issues/#findComment-12097234
