Budget and location:
Budget is aprox 1500-2000 gbp Im In Northern Ireland(shipping can be painful even from mainland UK) initial 1500 for the tower and another 500 for peripherals although im pretty flexible on pricing splits if it aids preformance.
Aims:
My main aim is to start a semi decent gaming rig as currently a laptop just isn't cutting it. I have no usable components as my last desktop is aproximately 10 years old and hasnt been in use for the last 8 of those years so please assume im starting from bare bones in terms of components.
Monitors:
Initially i plan to run 1 monitor with a possible upgrade to 2 further down the line.
Peripherals :
No Peripherals have been purchased open to recomendations.
Main reason for asking here is that i have no idea what options would be best for the motherboard and due to the GPU price fluctuation i have no idea if it would be a good idea to wait till 2019 to see what new hardware comes out or if some of the nicer GPU's will be restocked.
I have a preference to intel CPU's but I'm not unwilling to be persuaded otherwise if the price to preformance ratio works out.
Any help on getting somesort of viable system working would be much appreciated!
https://linustechtips.com/topic/1009684-first-build-in-a-while/
here's a build i made for you
white theme
ryzen 7
rtx 2080
144hz 1440p monitor
1.5 tb of storage
good cooler for ocing
https://linustechtips.com/topic/1009684-first-build-in-a-while/#findComment-12092726
3 hours ago, Hypa said:
never thought a 2080 would be viable on this kind of budget
having never worked with ryzen im not sure if this is a 2nd gen chipset and if it will be okay with just aircooling or further down the line would you recommend moving to a watercooler
So get 2600 and an AIO, then upgrade to gen 3 sometime in 2019, or later. 2600 is actually really good when paired with fast RAM.
Ryzen 3800X + MEG ACE w/ Radeon VII + 3733 c14 Trident Z RGB in a Custom Loop powered by Seasonic Prime Ultra Titanium
PSU Tier List | Motherboard Tier List | My Build
https://linustechtips.com/topic/1009684-first-build-in-a-while/#findComment-12092751
quote me next time :D or see I wont see that you responded
as for air-cooling it should be fine as the dark-rock is better than amds stock cooler and you can already hit decent oc's on that one
If you want you could always add another fan to it for like $15 if you arent satisfied with the performance
https://linustechtips.com/topic/1009684-first-build-in-a-while/#findComment-12092763
That's also a really good cooler (the dark rock) and is good enough for the 2700 and some overclocking.
https://linustechtips.com/topic/1009684-first-build-in-a-while/#findComment-12092765
Just having a look over benchmarks it seems the 2080 marginally better than the 1080ti and is it worth it for the real time ray tracing n'vidia has been promoting? it looks to future proof the build I'm aware and the 1080ti is as good as extinct to buy new but i cant help but make the comparison with what i've done a little research on.
Sorry for the mindless questions.
https://linustechtips.com/topic/1009684-first-build-in-a-while/#findComment-12092791
rtx is still kinda meh due to the low performance but it looks like it will become more and more utilized in the future
as for performance they are basically equal(think 1080ti is like 2% faster) and the only cards that will beat them are a 2080ti and the titan cards so it is very future proof
If you want you could also buy a used 1080ti if you can find one for a good price
https://linustechtips.com/topic/1009684-first-build-in-a-while/#findComment-12092816
Yeah i have seen a few hens teeth and found a few needles in haystacks recently so im sure finding a decently priced 1080 ti will be within my luck.
In all seriousness tho i'll do some digging into what the 2080 is capable of before making a final decision but thats a great build i really do appreciate the effort you put into the responce.
https://linustechtips.com/topic/1009684-first-build-in-a-while/#findComment-12092826
