Hio, so i have a i3 3240 (pls dont judge) and i've researched Amazon, Ebay, and other sites to get a cpu. I've got a GeForce GTX 1050 gpu and 8 gigs of ram. im upgrading to a ViewSonic VX2458-C-mhd 24" from an Asus VS247.
So CPU i got to the conclusion of an i5-7640X X-Series ($208.55 AUD) or an i7-4770 ($185 AUD). Should i buy it or you guys suggest one better for price and a bit less for performance. i'll use it for gaming.
https://linustechtips.com/topic/1009266-need-a-cpu/
EDIT: REDACTED. I thought the OP had a different socket.
You can't use the 7640x. It's a different CPU socket. The best CPU you can buy for that socket is a i7-4790k, but that's super overpriced.
I'd either go for the i7-4770 (non k) for ~ 110 USD or the i7-4790 (non k) for ~130 (USD).
https://linustechtips.com/topic/1009266-need-a-cpu/#findComment-12088687
Haswell CPUs are not compatible with the LGA1155 socket. Please make sure you know your socket types and rCPU compatibility when answering questions, as this can lead to people buying things that are not compatible, and would require a return, which sometimes is not possible.
@Mordicai The only CPUs that will fit in your motherboard are any Intel 2000 (sandy bridge) or 3000 (ivy bridge) series CPU. I would look for an i7-3770. That is the best CPU you can find for the socket, besides the 3770K, which is probably a good bit more expensive simply due to it being overclockable. That said, you can also look for an i7-2600. It's very close to the 3770 in performance, and might be a bit cheaper.
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
https://linustechtips.com/topic/1009266-need-a-cpu/#findComment-12088742
7 minutes ago, Cereal5 said:
Haswell CPUs are not compatible with the LGA1155 socket. Please make sure you know your socket types and refresh compatibility when answering questions, as this can lead to people buying things that are not compatible, and would require a return, which sometimes is not possible.
Ah, you are correct.
I had assumed his socket was the 1150 since his choices were either an 1150 chip or the performance version of 1150.. 2066.
Sorry about that.
EDIT: Yeah the 3770ks are overpriced (generally ~140 US), while the non k versions are usually ~85 USD. And you can always do BCLK overclocking if you have a board that supports it.
https://linustechtips.com/topic/1009266-need-a-cpu/#findComment-12088751
Also incorrect...... Well Haswell (4000 series) is 1150, but 2066 is the most recent high end desktop platform. The equivalent HEDT platform to ivy bridge (3000 series CPUs) would be Ivy Bridge-E (4820K, 4930K, 4960X), which uses the 2011 socket (not to be confused with 2011-3). 2066 is the newest HEDT platform, which uses Skylake-X and Skylake-X refresh CPUs (7000 and 9000 series CPUs that end in "X").
https://linustechtips.com/topic/1009266-need-a-cpu/#findComment-12088788
Damnit, you're right.
I'm off today. :)
EDIT: In my defense... the 7640x was literally 1 row away from the 2011s...
https://linustechtips.com/topic/1009266-need-a-cpu/#findComment-12088794
I was looking into a similar upgrade for my grandfather's computer.  I was considering a 3570k as it was quite a bit cheaper than the 3770k, but it doesn't have hyper threading.  I didn't feel super comfortable leaving my grandfather with an overclocked processor just in case he ran into any problems, so I ended up going with a 3770 instead.  I didn't consider going back to Sandy Bridge with the 2600 so I don't know how the prices line up, but that could be a good option too.
https://linustechtips.com/topic/1009266-need-a-cpu/#findComment-12088808
