Hello, i have questions about Racket programing language.
It's about designing a simulation using DrRacket big-bang environment. I have a structure that got:
; size is the size of shape
; color is color of shape
;type is form of shape
; posn is a posn structure and gives the location of shape
;structure:
$ (define-struct shape (size color type posn))
;constructors:
$ (define b1 (make-shape 10 "red" "c" (make-posn 450 350)))
$ (define b2 (make-shape 15 "green" "t" (make-posn 150 150)))
$(define b3 (make-shape 10 "purple" "c" (make-posn 250 200)))
$ (define b4 (make-shape 20 "orange" "s" (make-posn 320 450)))
$ (define b5 (make-shape 20 "blue" "t" (make-posn 280 300)))
  • Design key-f function which takes list-of-shapes and keyEvent and produces a list-of-shapes. The function checks the key event. If keyEvent is "s" then create a new shape as "square" and produce random colored shape with random size (between 0-30) and random position where x is between [0,WIDTH] and y is between [0,HEIGHT]. If keyEvent "c" then create a new shape as "circle" or if keyEvent is "t" then create a new shape as "triangle".
  • Design mouse-f function which takes list-of-shapes, x, y and mouseEventand produces a list-of-shapes on scene. The function checks themouse event. If it is \button-down", change the locations of all theshapes to align through a line around the clicked point
That's all what left from the project, thank you so much guys.
https://linustechtips.com/topic/1008904-help-with-racket-language/
