The VRM, as well as connectivity (RGB headers, SATA ports, maybe 10Gb LAN)
Desktop benching:
I'm glad you brought up VRM, what specifically is different?  Is it how consistently they send the voltage, or how much they can handle?
both.
more phases (real phases, those that do not turn on and off at the same time are considered separate) or higher mosfet switching frequency (you can only change this in high end boards) = less voltage ripple = more consistent voltage. switching frequency affects transient response so that's another thing.
Higher current output and efficiency mosfets = can push more current through each of them = more current capabilities as long as phase count doesnt drop
Desktop benching:
3 hours ago, Jurrunio said:
both.
thank you!  super helpful as always!
