USB hub or what?
By
ANUPLUCIFERGAMER
in Peripherals
in Peripherals
Solved by Sharif,
I've heard about them. are they good?
supposedly yes because if you get a usb hub you will have very less bandwidth than a pci version
smush ·
Posted in CPUs, Motherboards, and Memory2 -
asdasdasdasdasdasd ·
Posted in Hot Deals1 -
RipperDoc5456 ·
Posted in Troubleshooting4 -
Nebcs ·
1
FancyPants101 ·
