6 minutes ago, hypeftwmlg said:
Hey so my friend has saved up $600 USD and I have a gaming pc setup that is worth around that much can you tell me if it is any good for him to play fortnite Garry's mod and a few other games
https://pcpartpicker.com/user/Hypeftwmlg/saved/6QBtgs
Do you already own this PC listed in the PCPP list that you are going to sell your friend, or is this just something you have picked out on PCPP for your friend to buy?
Either way, that PCPP list is terrible and you should not buy it or sell it to someone you consider a friend.
  • Poor motherboard (not the worst out there, but there's better stuff for the price)
  • Slow RAM that will cause performance loss with that CPU
  • Useless GPU (you'd be better off with the Vega 8 graphics on the 2200G than the GT710)
  • No SSD
  • Fire hazard PSU
  • 1366x768 monitor
https://linustechtips.com/topic/1008053-need-help-on-gaming-pc/#findComment-12079002
build's a train wreck, get this instead and get os from reddit for $25.
CPU: AMD - Ryzen 3 2200G 3.5 GHz Quad-Core Processor  ($89.00 @ Amazon)
Motherboard: ASRock - B450 Pro4 ATX AM4 Motherboard  ($59.99 @ Newegg)
Memory: G.Skill - Aegis 8 GB (1 x 8 GB) DDR4-3000 Memory  ($53.99 @ Newegg)
Storage: Toshiba - P300 1 TB 3.5" 7200RPM Internal Hard Drive  ($39.99 @ Walmart)
Video Card: PowerColor - Radeon RX 570 4 GB RED DRAGON Video Card  ($144.99 @ Newegg)
Case: DIYPC - DIY-BG01 ATX Mid Tower Case  ($38.96 @ Newegg)
Power Supply: Corsair - CXM (2015) 450 W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($24.99 @ Newegg)
Monitor: Acer - KG221Q 21.5" 1920x1080 75 Hz Monitor  ($99.99 @ B&H)
Keyboard: Thermaltake - Commander Bundle Wired Gaming Keyboard w/Optical Mouse  ($33.98 @ SuperBiiz)
Total: $585.88
Generated by PCPartPicker 2018-12-13 23:30 EST-0500
https://linustechtips.com/topic/1008053-need-help-on-gaming-pc/#findComment-12079005
That GT 710 won't handle 1080p youtube, let alone gaming. The minimum he'd want is a GTX 1050ti.
There's going to be a video that linus literally JUST released on Floatplane (early access) on building gaming PCs at different pricepoints, including $500
I'm sure it'll be on Youtube in a couple days.
My rig:
CPU: Ryzen 7 5800x
MB: Gigabyte B450 I Aorus Pro WiFi
RAM: Kingston Fury Beast RGB 32GB (2x16GB) 3600mhz CL16 (1-to-1 Infinity Fabric enabled)
GPU: Gigabyte RTX 2080 Super
*bought for $200 CAD off a friend who needed an RTX 3080, price was my reward.
CASE: InWinn A1 Plus in White with included 600w gold sfx PSU and included custom length cables
DISPLAY: 3x 20" AOC 1080p 60hz 4ms ,  32" RCA 1080p/60hz TV mounted above, all on a single arm.
Storage: C : 1TB WD Blue NVMe      D : 2TB Barracuda      E: 240GB Kingston V300 (scratch drive)
NAS: 240GB Kingston A400 + 6x 10+ year old 700GB Barracuda drives in my old FX8350+8GB DDR3 system
Logitech G15 1st Gen + Logitech G602 Wireless
Steam Controller +  Elite Series 2 controller + Logitech G29 Racing Wheel + Wingman Extreme Digital 3D Flight Stick
Sennheiser HD 4.40 Headphones + Pixel Buds 2 + Logitech Z213 2.1 Speakers
My Girlfriends Weeb-Ass Rig:
Razer Blade Pro 17 2020
10th Gen i7 10875H 8c/16t @5.1ghz
17.3" 1080p 300Hz 100% sRGB, factory calibrated, 6mm bezel
RTX 2070 Max-Q 8GB
512GB generic NVMe
16GB (2x8GB) DDR4 3200Mhz
Wireless-AX201 (802.11a/b/g/n/ac/ax), Bluetooth® 5.1, 2.5Gbit Ethernet
70.5 Whr Battery
Razer Huntsman Quartz, Razer Balistic Quartz, Razer Kraken Quartz Kitty Heaphones
*deep breath*
Razer Raptor 27" monitor, IT'S BEAUTIFUL.
https://linustechtips.com/topic/1008053-need-help-on-gaming-pc/#findComment-12079007
Rule #1 of Floatplane is you do not talk about Floatplane.
https://linustechtips.com/topic/1008053-need-help-on-gaming-pc/#findComment-12079011
Let's see if mods don't like this
SPOLER ALERT, this is only for OP for helping his friend ONLYYYYY
Pfft I never signed an NDA when I joined floatplane
My rig:
CPU: Ryzen 7 5800x
RTX 2070 Max-Q 8GB
512GB generic NVMe
70.5 Whr Battery
*deep breath*
https://linustechtips.com/topic/1008053-need-help-on-gaming-pc/#findComment-12079018
Vega 8 integrated graphics in the 2200G should be fine for Fortnite and Garrys Mod, but if you want to upgrade to a dedicated GPU buy a used RX480 or similar off of craigslist. As @Herman Mcpootis mentioned you can get cheap keys for Windows on places like Reddit and Kinguin if you wanted to save a bit of money.
https://linustechtips.com/topic/1008053-need-help-on-gaming-pc/#findComment-12079032
Thanks I'll see if he likes them be us I looked on pcpartpicker for a while for the case so I'll see if it works
https://linustechtips.com/topic/1008053-need-help-on-gaming-pc/#findComment-12079052
