What case should I get that is cheap and has good airflow and pre installed fans
CPU: Ryzen 5 2600 @ 3.2Ghz
Motherboard: MSI B450 Gaming Pro Carbon AC
RAM: Team Vulcan DDR4 16GB (2x8GB)
GPU: Zoatac Gtx 1070 8GB
Case: CoolerMaster Masterbox Lite 5 RGB
Storage: 2TB Toshiba HDD, 120GB WD Green SSD
PSUGigabyte P650B
https://linustechtips.com/topic/1007783-case-help/
H500i
ASTRAY NOIR
CPU
Ryzen 5 3600
Cooler
Corsair H100I PRO
RAM
PNY XLR-8 EPIC-X DDR4-3200 CL16 32GB
GPU
ASUS ROG RTX 2070
STORAGE
SAMSUNG 850 EVO, 2xSEAGATE BARRACUDA PRO 1TB,A2000 1TB
Case
NZXT H500
PSU
Enermax Revolution DF 650W
MONITOR
MSI MAG272,LG 22MP68BQ,DELL D2015H
PERIPHIRALS
Ducky One 2 (HORIZON) || Glorious Model O- Pink || G305 || Razer Nari Essential || HyperX Cloud II
https://linustechtips.com/topic/1007783-case-help/#findComment-12076335
Whats the budget?
Focus G is a good cheap case for airflow, if you have more of a budget look at the Meshify C.
The mesh front panel is fantastic for airflow.
https://linustechtips.com/topic/1007783-case-help/#findComment-12076346
1 minute ago, Slottr said:
Whats the budget?
The mesh fron't panel is fantastic for airflow.
About £60
PSUGigabyte P650B
https://linustechtips.com/topic/1007783-case-help/#findComment-12076353
Just now, Ben a cava said:
About £60
Then I'd definitely go with the Focus G
https://linustechtips.com/topic/1007783-case-help/#findComment-12076357
Okay thanks
PSUGigabyte P650B
https://linustechtips.com/topic/1007783-case-help/#findComment-12076361
