RaspPi: need some help with autostart [Linux]
Solved by 0x21,
3 hours ago, firelighter487 said:but if you can use sudo commands without a password then that's a pretty major bug..
Default for raspbian is `pi ALL=(ALL) NOPASSWD: ALL` in sudoers file. This is not a bug.
4 hours ago, cluelessgenius said:so i know nothing of linux and i need a way to start openauto with elevated rights on startup
As user pi:
echo 'sudo ~/openauto/bin/autoapp' >> /home/pi/.bashrc
