Hi,
I've got an i7 3930k, a Noctua D9DX I4 cooler (overkill but it was a good price lol) and an ASRock Extreme6 X79 motherboard.
I'm going to be overclocking this system, so what do you think the best 24/7 stable overclock will be? I'm thinking 4GHz but I'm not sure about voltage.
Thanks in advance :)
https://linustechtips.com/topic/1007579-highest-possible-stable-overclock/
What is the clock speed and voltage at now
PC: CPU: i5-9600k - CPU Cooler: be quiet! Dark Rock Pro 4 - GPU: Sapphire Radeon RX 5700 XT 8GB GDDR6 - Motherboard: ASRock - Z370 Extreme4 - RAM: Team - T-Force Delta RGB 16 GB DDR4-3000 - PSU: Corsair - TXM Gold 550 W 80+ Gold Certified Semi-Modular ATX Power Supply - Case: Thermaltake - Core G21 TG
there's never a recommended frequency, but a recommended voltage upper limit. Mine will be 1.3V considering your cooler, but if temps allow you can go 1.35
Desktop benching:
I guess I'll just have to experiment. I'm thinking the max frequency will be about 3.8 (4 if I'm lucky), but it's probably best to just set it to a reasonable speed, then increase gradually until it starts being unstable
