Alternative Air cooling solution GTX1080ti
KhanBB
Hey Guys!
First of all: sorry, if I am writing some nonsense, I am not a native english speaker.
And surely this topic is already covered, I guess.
My question:
Actually I am using a GTX1080ti in Reference Design by PNY.
I am searching for a netter cooling solution. I never watercooled before, so my question is split in two:
Are there any other air cooling solutions then for example a Morpheus II?
And if I am going to watercool, is there any ONLY GPU watercooling-solution?
I am using an EKL Alpenföhn Olymp air cooler on my CPU, thats plenty of cooling.
Thanks for any advise and greetings from Germany!
KhanBB/Martin
My rig:
Windows 10
MSI X370 Titanium
Ryzen 2700X
G.Skill DDR4 32 GB
Be quiet 1000 Dark Power
M.2 Samsung 970 500GB (System)
M.2 SATA Samsung 500 GB
SSD Samsung 840 500GB
well, artic has some nice air coolers for those. otherwise you should probebly go with watercooling. Don't know that much about water cooling tho
The morpheus II is great, a guy on a discord server I'm on put one on his 1080 Ti and the temps are amazing, but IMO it's kinda ugly. Another good option is a 120mm AIO + mounting kit, but those will probs cost more than the morpheus + 2 fans.
Main PC
CPU: i9 7980XE @4.5GHz/1.22v/-2 AVX offset
Cooler: EKWB Supremacy Block - custom loop w/360mm +280mm rads
Motherboard: EVGA X299 Dark
RAM:4x8GB HyperX Predator DDR4 @3200Mhz CL16
GPU: Nvidia FE 2060 Super/Corsair HydroX 2070 FE block
Storage:  1TB MP34 + 1TB 970 Evo + 500GB Atom30 + 250GB 960 Evo
Optical Drives: LG WH14NS40
PSU: EVGA 1600W T2
Case & Fans: Corsair 750D Airflow - 3x Noctua iPPC NF-F12 + 4x Noctua iPPC NF-A14 PWM
OS: Windows 11
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 2020 M1 MacBook Air (work computer) - iPhone 13 Pro Max - Apple Watch S3
Other Misc Devices: iPod Video (Gen 5.5E, 128GB SD card swap, running Rockbox), Nintendo Switch
I don't know anything about reference cards, maybe more case fans? but water cooling is available at NZXT with their Kraken G12, you would need to take off the ref cooler and install this bracket, you'll also need to buy an AIO that is compatible, this link is to NZXT for this product https://www.nzxt.com/products/kraken-g12-white if you don't trust the link from a stranger on the web, look up NZXT Kraken G12 and it should come up. it claims to be compatible with the 1080ti but I would double check but it is a cheaper solution than custom water cooling and is better than air. JayzTwoCents has a video on it and how to install and whatnot here
I am about to install this combo onto my reference EVGA 1080ti. The NZXT Kraken G12 mounting bracket and the Corsair H55 liquid cooler.
https://www.corsair.com/us/en/Categories/Products/Liquid-Cooling/Single-Radiator-Liquid-Coolers/Hydro-Series™-H55-Quiet-CPU-Cooler/p/CW-9060010-WW
Thx! I will chech the Kraken and the video!
Checked both, but the g12 and a cpu watercooling solution will get to around 200€/200$. Thats a bit much.
Anyone else with a great idea of cooling the GPU alone? Thx again!
Pls write about your experience! TY
  • 1 year later...
I know it an old thread, sorry for reviving the old thread but hows that working out for you? just curious.
