i5 6500
16gb ram
rx 470 8gb vram
650w corsair psu
pc has very slow performance in windows and in google chrome(my brother opens pc starts discord then watches youtube video and at the end of the video pc freezes and he presses reset button,he tells me everyday it does this.
i open pc go to facebook and some times weird artifacts are showing or its not rendering like it should.i start pc and some times it shows the windows loading screen and stuff and then the monitor gets no signal,i try to unplug and plug hdmi or try different one no solution except reset button,today i had to reset the pc 5 times cause either no screen,or it would not past windows loading screen.
i have 3 drives C which is ssd and has windows,D which is where i put games,and F which is drive for photos and as a backup.
i want to format C and D but don't want to delete F how do i do that,i have windows 10 1803 and i want to do it today cause its so bad performance plz answer quick
https://linustechtips.com/topic/1007327-pc-performance-problems/
On the windows installer it should ask you where you want to install so it should show all drives seperately. Doing so you can format drive C and D there and select C as the install drive. If you're reeally scared you can deconect drive F so the system can't touch it.
Double check for driver updates first especially for the GPU, my cousin has an rx-580 that would eventually cause his computer to shut off after like 30 mins and once he did driver updates the issue was gone
Optical Drive Poll: https://linustechtips.com/main/topic/1006309-optical-drive-survey/
Main Rig (Pulsar)
CPU: Ryzen 7 5800X MOBO: MSI MEG X570 Unify RAM: Corsair Dominator Platinum RG(4x8gb) 3200Mhz 16-16-16-32 GPU: EVGA GTX 1080 FTW ACX 3.0 Cooler: Noctua NH-U12S Chromax (LTT Edition) Storage: Intel 6000p 128gb boot drive, Intel 665p 1tb (x2), Samsung 850 EVO 1tb, Case: Phanteks Enthoo Pro M Tempered Glass PSU: EVGA SupeNOVA G1+ 750W OS: Windows 10 Pro 64 bit
FreeNAS Server (The Vault)
CPU: Xeon E5-2603 v3 MOBO: MSI X99 Tomahawk RAM: G.Skill Aegis (4x8gb) 3000Mhz 16-18-18-38 GPU: EVGA GT 710 Cooler: Cooler Master Hyper 212 LED Storage: Intel S3520 x2 for boot, x16 in RAIDZ for storage, Seagate Ironwolf 2tb (Striped will be a steam cache) Case: Phanteks Enthoo Pro Tempered Glass PSU: Corsair CX750 750W
Sounds like your windows is corrupted causing errors, otherwise it sounds like ram / video card or driver problem. Depends how old the pc is in that case, but more likely just windows corruption. Its easy to reinstall windows when all your drives are separate you don't have to worry about loosing data. As Thekingofsalt said just physically disconnect the other drives when installing windows.
