Part Swapping between PC's (ADVICE)
Solved by Fasauceome,
4 minutes ago, campy said:nopenopenoepnope
just google the model name and you can see what it is
its not hardline water cooling, its not custom watercooling, its just a very compact AIO water cooler
That sure looks good for a graphics card upgrade, a founders edition 1070 or so would be awesome in there.
