I've been having a black screen/ rebooting issue for a month or so now. My linked thread down there is a detailed discussion I had a bit ago that talks about my issue. My latest reply was this:
Quote
Sad to say I've encountered the issue again after 4-5 days of use. Within that time, I had no issues. Is there any info you guys would like? I saw that I got a "Power Kernel error" in Windows Event Viewer. Also, my DRAM voltage auto-ed to 1.2volts so I bumped it to 1.35.
I know that opening threads on the same topic is looked down on, but I don't think there's much of a chance of my old thread getting noticed again. So since we went into detail about the issue and what's going on, here's the old topic for context. Just tell me if I need to delete this for any reason.
Thank you very much.
Thoughts become things. What you hold in your mind, you will hold in your hand.
Be happy for yourself.
My rig :) :
PCPartPicker Part List: https://pcpartpicker.com/list/tX4hWD
CPU: AMD - Ryzen 7 2700X 3.7 GHz 8-Core Processor
Motherboard: Asus - Prime X470-Pro ATX AM4 Motherboard
Memory: Corsair - Vengeance RGB Pro 16 GB (2 x 8 GB) DDR4-3200 Memory
Storage: Samsung - 860 Evo 500 GB 2.5" Solid State Drive
Storage: Seagate - Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive
GPU: Gigabyte - GeForce GTX 1080 Ti 11 GB AORUS Video Card
Case: Fractal Design - Meshify C ATX Mid Tower Case
Power Supply: SeaSonic - FOCUS Plus Gold 650 W 80+ Gold Certified Fully Modular ATX Power Supply
Operating System: Microsoft - Windows 10 Home OEM 64-bit
Monitor: AOC - G2770PQU 27.0" 1920x1080 144 Hz Monitor
Keyboard: Corsair - K70 RGB RAPIDFIRE Wired Gaming Keyboard
Mouse: Corsair - Sabre RGB Wired Optical Mouse
Custom: Beyerdynamic DT 770 PRO, 250 ohms
https://linustechtips.com/topic/1006271-help-with-blackscreens/
Just now, barondeau said:
That might be a cooling issue, but I am guessing that the old thread would have discussed it, you could try using a default OC profile on your bios
Sure, I'll try a default profile. The thing is if my RAM can't run to advertised speeds, I need to address that, y'know. and I'll monitor temps more often. Thank you for the insight!
My rig :) :
https://linustechtips.com/topic/1006271-help-with-blackscreens/#findComment-12061812
