RivaTuner help needed
Solved by WhatComesAround,
Hey, this is future you. Basically, idiot, you go into the rivatuner settings and then you turn of that show own statistics thing you turned on for no reason... Hope that helps, it would help if you didn't fiddle with things you don't understand ._.
HunterSVK ·
Posted in Troubleshooting0 -
Ozzi ·
Posted in Networking2 -
1
MadManMarsBar ·
Posted in Build Logs0 -
IAmAndre ·
Posted in New Builds and Planning7 -
4
3
Playgb2 ·
Posted in Troubleshooting1 -
2
1
play_circle_filled
Latest From ShortCircuit:
