My 2 month old Seagate 1TB HDD is making a scratching noise but works fine and is not slow at all.
From what i've heard is that when this happens its failing and will probably break soon.
I tried SeaTools for a temporary fix but its still making a scratching noise.
I have all my important stuff on my 250 GB SSD so I'm not worried about losing files at all.
Is there anything I can do?
https://linustechtips.com/topic/1005227-2-months-old-seagate-hdd-problem/
That doesn't sound good. (pardon the pun)
If you are still covered by warranty, I suggest you to send it back for a replacement.
In the mean time, try do a full drive back up to local machine or cloud just in case.
"Mankind’s greatest mistake will be its inability to control the technology it has created."
