What CPU?
Desktop benching:
1 minute ago, spree said:
i7 7700k
then you should use manual to get the LLC settings correct, then use offset mode to get the final voltage correct.
Desktop benching:
Why not use the dynamic/offset direcly? Doesn't this allow the CPU to get more voltage only when needed?
because using some LLC allows the voltage between idle and full load to be more different, in other words lowering idle voltage and power draw further. However maxing out LLC for lowest idle voltage isn't really good for your CPU either because LLC induces more voltage spike. That's why you would want medium levels of LLC, just enough to remove Vdroop as much as possible, before you start using offset mode.
Desktop benching:
I'm not sure we are talking about the same thing. I am not asking if I should overclock with vcore loadline calibration. I'm asking if I should use CPU Vcore or the Dynamic Vcore to change the voltage.
my answer is to use manual voltage mode to get LLC right and know the exact voltage needed for stability, then try make offset mode output the same voltage under full load with the same LLC settings
Desktop benching:
