Hello,im looking to build a new pc,i already bought a gtx 1070 gaming x... I need help choosing the other parts.. Since im from Serbia,just list out the parts to me,and i will tell you the price in Serbia... Im looking to spend about 750e.I need the parts list without the gpu. Thanks!
https://linustechtips.com/topic/1004874-need-help-with-choosing-components/
What games are you going to play
Having seen this picture before, you're probably looking for either an i5-6400 or a Ryzen 5 1600, probably on a Gigabyte motherboard, 8 Gb of DDR4 2666 with a Corsair power supply (500w 80+ Bronze is good).
@GoodGamer2018  Everything lol... I will play anything that i find interesting... Including AAA titles....
For the cpu go either Ryzen 5 1600 or i7-8700. 8 or 16gb of DDR4 2400MHZ Ram. PSU should be a bronze certified 600 Watts and just pick a Motherboard that is compatible and is interesting to you.if the cpus are to high go for the Ryzen 3 1200 or i3-8100
ryzen 5 2600, b350 (eg asrock pro4), 8gb 3000mhz+ ram, some cheap / free case, 250gb sata ssd, 2tb hdd, decent 60 euro 500W+ psu
or
i5 8500, b360 mobo, 8gb ram, some cheap / free case, 250gb sata ssd, 2tb hdd, decent 60 euro 500W+ psu
Samung Tab S 8.4
or
i5 9500, b360 mobo, 8gb ram, some cheap / free case, 250gb sata ssd, 2tb hdd
The cpus that you name are too high for @Nikolacar4 budget
@GoodGamer2018 @H4X3R They are not lol... The 2600 is 150e... 16gb of vengance rgb@3000 is 150e.. Case is 60e. Ssd+hdd=100e... And then i dont know what mobo to buy... It's like this:I could stick to 2600+b450-f and get an ml240r. I can do 2700+b450-f (stock cooler). Or i can do 2600+Hero VII Crosshair.. What to take?
i5 8500 is 230 euros + mobo (75 euros) + 8gb (60 euros) + case (0-20 euros) + 250gb sata (60 euros) + 2tb hdd (60 euros) + psu (60 euros) = 565 euros.
Samung Tab S 8.4
2600 + b450 + a decent air cooler (eg be quiet dark rock 3) -- 60 euros,
Samung Tab S 8.4
