need some help
Go to solution Solved by Steve George,
I would suggest you start with the basics such as html then you advance to other languages if you are new to programming
You mean IBM Watson program? I don't think you should start trying to learn programing with it, that's like the highest end and sophisticated AI out there.
If you have no background usually the easiest stuff to get started to understand programming mechanics is with HTML coding.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/1004820-need-some-help/#findComment-12048966
Just now, Joeballs187 said:
yes the watson programing the drawing the linds over words is better i dont type so well i liked it i ever was ready to do @ and # wanted to update a vets website with a bot and moblie optamzaion
well, you really shouldn't try watson if you're not known with programming in general. try html, java(script) or python first. there are many IDE's and guides that can help you out there.
https://linustechtips.com/topic/1004820-need-some-help/#findComment-12048975
4 minutes ago, LukeSavenije said:
what programming language do you want/need to learn? python? javascript? java? C#? C++?
i dont know any and if i dont have to code that would be great for at first i wana but maybe i need some idk anything just wanted to do this bot thing and the wordpress thing
https://linustechtips.com/topic/1004820-need-some-help/#findComment-12048976
well, i'll ask something else than. what the hell are you planning on doing?
https://linustechtips.com/topic/1004820-need-some-help/#findComment-12048977
3 minutes ago, Joeballs187 said:
idk learn and come up with an idea like if i get that drone im going back to do a visual traning for a red horn i have on my hoodie so the drone fallows me
well, then you should learn to program first. I would do that inside something like html, java(script) or python for example. try learning that, and then try to do those things
https://linustechtips.com/topic/1004820-need-some-help/#findComment-12048989
