Hello everyone,
What is the best future-proofing graphics card for 1920x1080 resolution???(1080p)
Nvidia and AMD. (Need answers for both)
CPU:  Ryzen 7 2700X 8 Core 3.70 GHz and will be using the stock cooler
RAM: G.Skill - Ripjaws V Series 16 GB (2 x 8 GB) DDR4-3200 Memory
Monitor:  I'll be using any 1920x1080 monitor that have 144hz either with gsync, freesync or without.
QUOTED ANSWER: (Need answers for both)
1.--Nvidia
2.--Amd
Thanks and happy gaming...
PS. Will be playing real high-end games and maybe do some productivity too who knows.
https://linustechtips.com/topic/1004766-need-help/
10 minutes ago, KnightyNight said:
Hello everyone,
1.--Nvidia
2.--Amd
For future proofing it kind of depends on how far you are willing to go (aka how much to spend). You could get a 1080 and be set at 1080p for a decent bit, or grab a 2080 Ti and not need to upgrade for 1080p for (most likely) quite a long time.
Nvidia: Get a 2080/Ti most likely. They do 4K ultra at 60fps, so 1080p ultra 144fps will be a cake walk
AMD: RX 590 is pretty ok at 1080p, but a Vega 56 or 64 is probably your better bet for "future proofing" here. AMD cards are generally behind and its harder to future proof with AMD cards. The Vega 64 is ~= to a 1080, so that's what I would go with in the red camp. But if you want to be set for a long time, go RTX
Primary PC: - https://pcpartpicker.com/list/8G3tXv (Windows 10 Home)
HTPC: - https://pcpartpicker.com/list/KdBb4n (Windows 10 Home)
Server: Dell Precision T7500 - Dual Xeon X5660's, 44GB ECC DDR3, Dell Nvidia GTX 645 (Windows Server 2019 Standard)
*SLI Rig* - i7-920, MSI-X58 Platinum SLI, 12GB DDR3, Dual EVGA GTX 260 Core 216 in SLI - https://pcpartpicker.com/list/GHw6vW (Windows 7 Pro)
HP DC7900 - Core 2 Duo E8400, 4GB DDR2, Nvidia GeForce 8600 GT (Windows Vista)
Compaq Presario 5000 - Pentium 4 1.7Ghz, 1.7GB SDR, PowerColor Radeon 9600 Pro (Windows XP x86 Pro)
Compaq Presario 8772 - Pentium MMX 200Mhz, 48MB PC66, 6GB Quantum HDD, "8GB" HP SATA SSD adapted to IDE (Windows 98 SE)
Asus M32AD - Intel i3-4170, 8GB DDR3, 250GB Seagate 2.5" HDD (converting to SSD soon), EVGA GeForce GTS 250, OEM 350W PSU (Windows 10 Core)
*Haswell Tower* https://pcpartpicker.com/list/3vw6vW (Windows 10 Home)
*ITX Box* - https://pcpartpicker.com/list/r36s6R (Windows 10 Education)
Dell Dimension XPS B800 - Pentium 3 800Mhz, RDRAM
In progress projects:
*Skylake Tower* - Pentium G4400, Asus H110
*Trash Can* - AMD A4-6300
*GPU Test Bench*
*Pfsense router* - Pentium G3220, Asrock H97m Pro A4, 4GB DDR3
https://linustechtips.com/topic/1004766-need-help/#findComment-12048414
1070ti
Vega 56
Desktop benching:
https://linustechtips.com/topic/1004766-need-help/#findComment-12048452
