New Power Supply / New UPS
Solved by Patrick3D,
I have been using CyberPower 1500VA Adaptive Sinewave UPSes for about 3 years now with no issues. I run a file server off of one and my entire home theater system (Receiver, TV, HTPC, Ethernet switch) off of another, 24/7. In rural Illinois with bad power as well. They go for around $200-$230. They include a USB connection and have software that lets you see the current load and has a history of any power events. Also, very easy to disable the alarms on them. I've been through multiple blackouts and brownouts without needing to replace the batteries yet.
