Wraith Max color problem
Go to solution Solved by Qwiss,
5 hours ago, Stefan Payne said:
NO; DO NOT DO THAT!
THE CONNECTOR IS NOT REVERSIBLE!
Just try the other connector.
And see if you really used it the right way.
Guess what. I flipped the rgb cable. And now it works!!!!
thank you all for your help!
So, I basically got a new PC because my old one was kinda bad. And I went AMD, and I decided do buy the AMD Wraith Max cooler for my 1600x. The problem is, when I first connected the cooler to the fan, the rgb sync worked well. Now, when I got it into the case and I connected it into the same CPU LED header, the color blue won’t show up at all and colors cycle only through green, orange and red. Can you help me please? ?
P.S: This is the first PC I’ve built.
Motherboard: Aorus B450 Pro
CPU: Ryzen 5 1600X
CPU Cooler: AMD Wraith Max RGB
https://linustechtips.com/topic/1004093-wraith-max-color-problem/
Your video doesn't work.
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
5 hours ago, Qwiss said:
It does work for me. :(
Maybe because you have it on Harddisc??
You connected the RGB Header the right way??
I really hate that they didn't code the connector...
"Hell is full of good meanings, but Heaven is full of good works"
Yes I did. I connected the RGB Header the right way, because I’ve connected it before when I tested the PC out of the case. I’m gonna try to flip the cable or something. Also the video problem is probably because I’ve posted this from my iPhone.
NO; DO NOT DO THAT!
3 hours ago, Stefan Payne said:
NO; DO NOT DO THAT!
I don’t have another connector, I only have the CPU_LED header on my motherboard which is specifically for the rgb for the CPU Cooler. And by flipping I meant turning it around. I honestly don’t know what to do. It worked before just fine, it won’t now. ;(
NO; DO NOT DO THAT!
