8 minutes ago, Dunno said:
What do you mean by pressure?
Most likely not but I ask it anyway  - Is there anything I can do about it?
well, all says it was something that has pressed onto the screen, could have happened with transporting it for example. not much, you might be lucky and it goes away, but that's about it
https://linustechtips.com/topic/1003872-how-long-will-it-live/#findComment-12040634
The monitor is 6 years old. This thing showed up only 6 months ago. I didn't apply any pressure too. while transporting but showed up 5 years later?
https://linustechtips.com/topic/1003872-how-long-will-it-live/#findComment-12045219
no, I was thinking about recently (6 months ago for you). it looks like it, I wasn't sure about it.
https://linustechtips.com/topic/1003872-how-long-will-it-live/#findComment-12045226
