Hey guys,
I'm building a system for my friend rn and he told me that he wants a custom loop in the NZXT H200 case.I've seen a few custom loops in that case already so I know it's possible.
It would consist of a 120mm radiator on the back exhaust and a 240mm radiator on the front of the case.
I'm thinking of putting the pump under the PSU shroud if it's possible. The reservoir would be mounted next to the motherboard.
Do you think it is a good idea?
Do you have any tips/ideas that would come in handy?
Do you think that I should build it differently and if so please tell me how.
Thank you!
https://linustechtips.com/topic/1003808-custom-loop-in-a-mini-itx-case/
if you can jam it all in there, there is no reason it wont work
What are you concerned about?   performance afterwards or buying stuff and not being able to actually finish it?
And after its your case you can do anything you want to it, including mods like mounting shit wherever you want. and drilling holes/etc if you want to.
Although i would do some major inspection of how 'thick' your rad could be if you put it there, and  would you be able to have fans on it too
