I'm trying to build a rig that will allow me to use blender and a game engine for developing but, I'm not sure when it comes to choosing components. i.e. compatibility and I know just putting the biggest CPU and GPU doesn't mean you will have the best performance. I have $5,000 to spend. If someone could point me in the right direction that would be great thanks.
https://linustechtips.com/topic/1003804-pc-build-help/
https://linustechtips.com/topic/1003804-pc-build-help/#findComment-12040528
