4 minutes ago, M.Yurizaki said:
What are  your parts? And does UEFI detect the drive?
Mobo: B450 Aorus Pro Wi-Fi
Everything else is detected in the BIOS, I think... at least the CPU and RAM.
I'm guessing GPU too since I have video output on the monitor connected to it.
What is UEFI?
https://linustechtips.com/topic/1003567-m2-drive-not-detected/#findComment-12037585
What is UEFI?
UEFI is the BIOS.
Looks like both M.2 slots on that board are PCIe.  Only 1 can do SATA tho.  Are you sure it's a PCIe M.2 drive?
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1003567-m2-drive-not-detected/#findComment-12037617
4 minutes ago, jstudrawa said:
UEFI is the BIOS.
970 EVO, and I connected it to the slot that supports PCIe (followed the mobo manual)
I think the problem is I need the samsung drivers.
Could you please help me out?
On the Windows Setup there's an option to "Load driver", so I downloaded the .exe file (driver installer) from samsung, saved it in a USB, connected it to the PC, but windows says theres no driver in it.
What do I do?
https://linustechtips.com/topic/1003567-m2-drive-not-detected/#findComment-12037644
What do I do?
You shouldn't need drivers. I have a B450 board with a 970 EVO and my install went without a hitch.
What are you installing Windows from? DVD from Microsoft? USB key you built from the Media Creation Tool?
https://linustechtips.com/topic/1003567-m2-drive-not-detected/#findComment-12037654
This one
Then what's the issue? :(
Redo the build or try another USB stick. Alternatively get a live version of Linux distro like Lubuntu or Mint and see if it finds the SSD.
https://linustechtips.com/topic/1003567-m2-drive-not-detected/#findComment-12037691
Guess what! lol
So apparently when I placed the NVMe heatsink (the one that comes with the mobo) it accidentally moved the drive, it was slightly out but just enough to not be detected
https://linustechtips.com/topic/1003567-m2-drive-not-detected/#findComment-12038943
