I m planning to upgrade my everyday laptop, decided to go with Thinkpad E580, which has lots of ports, but missing VGA (mandatory for legacy projector support) and display port.
Laptop has single USB-C port, which is used for charging as well.
My requirements are following
1. VGA port (at least 1080p@60)
2. Display port (preferably 4K@60, but 4K@30 will do as well)
3. USB-C PD (Power passthrough,  >60W)
4. Couple USB 3 type A ports (Preferably latest gen)
5. SD/Micro SD reader (optional, laptop has micro SD)
6. HDMI 4K (optional, laptop has one)
7. RJ45 1GB not mandatory (laptop has one)
So far I found one AUKEY USB C Hub, with only downside  no display port, I guess I can by passive small size HDMI to DP dongle but I prefer to have Display Port (full size) on USB hub itself, even if it replaces HDMI
Can someone suggest such hub?
https://linustechtips.com/topic/1003501-usb-c-hub-suggestions/
  • 3 months later...
