So I have a Dell 690 0MY171 motherboard that is presently running a Xeon 5160 Dual Core, and an NVDIA Quadro FX 3450. I'm trying to figure out what I can upgrade. I haven't tried opening up the box yet. Mostly I'm looking to be able to play some more modern games on the level of The Vanishing of Ethan Carter or X Rebirth.
What I don't know is what hardware should I be looking at, and what I should be trying to upgrade?
https://linustechtips.com/topic/1003428-need-help-upgrading-an-older-computer/
i think you may want to start fresh... just my opinion. if you got a budget in mind, i can get you a build you will want rather quickly
Rig 1: i7-9700k OC'd to 5.0ghz all core | EVGA XC RTX 2080Ti | ADATA DDR4 2400mhz 4x8gb | ASUS PRIME Z370-P | Asetek 550LC 120mm | ADATA 480GB SSD & Toshiba P300 3TB | Cooler Master Masterbox MB500 | Win 10 Home | Logitech G910 Orion Spectrum, G502 Proteus Spectrum, G933 Artemis Spectrum Snow Wireless Limited Edition, Corsair MM300 Mouse Pad | 2 MSI Optix Curved 27" FHD Monitors
(before i sold the WD drive and MSI gpu - https://www.userbenchmark.com/UserRun/11946219 171 gaming. felt good.)
Rig 2: i7-7700k Stock clocks | MSI Armor GTX 1070 | ADATA DDR4 2400mhz 2x8GB | MSI Z270 A-Pro | WD Green 240GB SSD & 2TB Seagate HDD | Thermaltake Core G21 Tempered Glass Edition | Win 10 Home | 2 HP Omen FHD 144hz 24.5" Monitors
Rig 3: i7-6700 | GT 730 & GT 645 OEM | Some random DDR4 2133mhz 2x8gb sticks | OEM Dell Mobo | WD Black 2TB HDD & Toshiba 1TB HDD | Win 10 Home | 3 27" Dell FHD Monitors
Rig 4: i7-4770 | EVGA SSC 1050ti | Some random DDR3 ram 2x2gb and 2x4gb sticks | OEM Dell Mobo | Stock Cooler | 1TB WD Black HDD | Win 7 Home
RIP
Rig 5 (dead and dismantled and sold) : i7-7820X OC'd to 4.8ghz all core | MSI DUKE 1080ti | ADATA DDR4 2400mhz 4x8gb | Gigabyte X299 UD4 PRO | Asetek 240mm AIO | WD Green 240gb SSD | Other various components that I can't remember
Rig 6 (same fate as rig 5) i7-8700k stock clocks | MSI DUKE 1080ti | ADATA DDR4 2400mhz 2x8gb | MSI Z370 A-Pro | Asetek 550LC 120mm | WD Green 240GB SSD & Toshiba 2TB HDD | Other various components that I can't Remember
your best off going with a whole new computer and selling what you currently have for what you can to put towards a new pc
